Set of velocity stacks for the VTR, these are the " Dr Honda - Bill from H Power" variant.. both the same length and designed to give you a bit of a boost where you need it most.
There are threads here and on the Superhawk forum for these and the reviews to go with them. Most seem to give a positive response and people like them a lot.
These have been made with a mounting plate rather than in one piece so should you have other stacks available such as the mori's short and tall, they should also fit and allow you a little bit of tuning.
They will require a little mod to the airbox, as all the stacks in the past have, to allow fitting and is easy to do ( some bits of plastic get in the way ). This is simple to do and shouldn't be a problem in any way.. and will be apparent when you go to fit them. No more hidden surprises.
I am asking £75 for the stacks and mounting plates plus postage depending on where you are in the world.
Aluminium Velocity Stacks
Moderator: VTRDark
- agentpineapple
Re: Aluminium Velocity Stacks
Look very well made .someone will get a bargain
- Pete.L
I'm impressed with that!!!
Wish I had a use for them:-) I think anyone would be pleased owning those. Only problem is, if they were mine, I would want a clear Perspex air box to show them off:-)
