I have a VTR that i will be working over the winter. it is fitted with a blade front end and yokes plus WP springs.
Does this mess up the steering set up? I know the storm doesn't have the best geometry. compared with more modern bikes, but it what i am used to and i wouldn't want to make it worse
NOT USD forks
Blade front end
- alanfjones1411
Re: Blade front end
I have a set of 954 blade forks USD. They seem to be better to me and give good feel while cornering. But as stated mine are USD. Hope this is of some help to you.
Re: Blade front end
If it isn't broke don't fix itStuartWags wrote:I have a VTR that i will be working over the winter. it is fitted with a blade front end and yokes plus WP springs.
NOT USD forks
Like what you do
Do what you like He who wonders isn't always lost
Re: Blade front end
Blade forks are slightly shorter and so if you like a bike to feel "front-endy" then it's a good upgrade.
Don't drop them through the yokes as it gets too slappy.
But also you will lose a little ground clearance, if you already scrape pegs then it will make it worse.
Re: Blade front end
interesting ... i don't scrap pegs on the road but needing more ground clearance i found on the track......tony.mon wrote:Blade forks are slightly shorter and so if you like a bike to feel "front-endy" then it's a good upgrade.
however it also has harris rear sets.
it looks like the standard blade yokes with the forks about flush when i got it
this is what it look liked 9 years ago before it sh@t the cct and stood a a shed growing a crust... it is not so pretty now but should scrub up with some elbow work
Re: Blade front end
I have 96 blade forks, 6mm raised rear end, stock rearset, and I find ground clearance sufficient. I scrape the pegs on track, but rear tire has no chicken strips, so it is fine, though there is little more angle tires can handle. But I can remove ground checkers from pegs to get more clearance.
