lazy starter
lazy starter
or should that be non starter.
this last while its been getting lazy to start and if i left it for a week it just about turned over and fired. so new battery time. popped a new battery in and its the same. itl turn over maybe once then just getting a wheeze out the starter motor . no clicking or anything just tries as if the batteries flat?.. got the bike to bump down the hill at my house and runs fine, no problems but not on the button..?
starter motor im hoping???
Re: lazy starter
Have you taken the rubber boot off the front, given it a dam good clean and check? Common falter.
Also, what else do you have on as extra, alarm etc draining the battery? Even if you have a charger lead plugged in that might be enough.
Apart from that wait till pineapple is back from his tours and do a refurb exchange with him.
Don't hassle me
I'll get there at some time
Re: lazy starter
iv nothing else hooked up to it.. its been getting slower of late which made me think new battery would sort it, had a wee look at the rubber boot and its a bit rusty under it so have to give that a cleangrumpyfrog wrote:Have you taken the rubber boot off the front, given it a dam good clean and check? Common falter.
Re: lazy starter
Or could be a bad earth somewhere ?
Re: lazy starter
what sort of rec/reg have you on the bike
are the battery connections clean/tight
can you take a volt reading when not running and then running
as the men have said ,starter connection clean
Re: lazy starter
strange thing is it runs fine when bumped, its got a later finned type rec. and iv lost my bloody multi meter . i pulled the rubber boot of and when i tried starting it i could feel and hear the starter motor try to turn then squeel kinda. the conection on the starter was pretty bad with rust and i had to cut the bloody nut of. iv a mate dropping me a fireblade one round that i know works so il try that..macdee wrote:what sort of rec/reg have you on the bike
Re: lazy starter
Ok
clean the connection and try your starter first ,just to tick off that check
Re: lazy starter
starter seems to tuen over a few times then just wheezes.. new starter required i hope?
Re: lazy starter
Also worth noting don't get into the habbit of bumping this beast- some sort of spog gives up the easily and is a mare to fix.
Get some jump leads or a booster pack.
Don't hassle me
Re: lazy starter
thats what im afraid of. i tried jump leads from the car and it was just the same . hopfully get my hands on this other starter tomorrow and try that.grumpyfrog wrote:Also worth noting don't get into the habbit of bumping this beast- some sort of spog gives up the easily and is a mare to fix.
Re: lazy starter
If you found the bolt on the starter corroded then that's more than likely the problem, as not not enough electrickery juice can get through the rusty resistance. Plus if you haven't kept it greased under the rubber hood then the corrosion has also probably worked its way past the internal fibrewashers knackering it also on the inside.
It's possible to strip and refurbish the starter motor with a stainless steel bolt or simply swap with a starter from any 600cc+ honda from late 90s/earlynaughties. Good condition Hornet ones can be had cheaply on fleabay.
Re: lazy starter
+1 with Wicky you can take it apart i had the same issue with my silver storm you can get a cheap cbr600 one that matches up fine there quite a range that use the same starter motor
Re: lazy starter
happy days lads im hoping thats all it is. it was very rusty and iv a mate dropping me round a 97 blade motor which should be the same . bloody weather is blazing and im stuck riding my wee divvie atm...
Re: lazy starter
ell cleaned all the connections. charged the battery ,popped in the new starter that i know works fine and hit the button. and the big pile of yellow shite is the same. tries to turn over maybe once then sounds like it has no power to turn over the engine .....
Re: lazy starter
So if you have a new fully charged battery and a known working starter then something isn't right between the two - time to check check the starter relay / power lead and that all connections between all are clean and tight.
