Well, lovely day, went for a run on CBR after working on VTR, got back, changed oil, head bearings, decided to take Storm for a storming...no keys..must have had them in my pocket when I took the CBR out..ffs what a stupid xxxx
Can I get a key from a code or something?1998
Lost key
- rollingthunderx2
Re: Lost key
If you've lost the only key then you'll need to remove the ignition lock/barrel and take it a decent reputable locksmiths - If there's a serial no. on the bottom of the ignition switch then contact Honda. Goodness know what it will cost £20-£40 - getting a duplicate key cut about a fiver.
At least you don't have HSS!
Re: Lost key
Key number mite be stamped under ignition as on older Honda I have seen them
So remove ignition an look.??
- rollingthunderx2
Re: Lost key
Ok, Thanks, guys.
