Firebrand forks air gap?
grumpyfrog
Post by grumpyfrog »
My 2000 firebrand forks are weeping, anyone know what the air gap should be when refilling the oil is? Also what weight of oil I should be using?
2000 rrx model forks I'm sure!
Don't hassle me
I'll get there at some time
Re: Firebrand forks air gap?
7.5 - 140mm
Have a search as it's been covered before with a few different recommended variations.
grumpyfrog
Cheers wicky.
Don't hassle me
thunderbolt
Post by thunderbolt »
I am using 130mm on my forks and grade 5 oil.
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
Er correct me if I'm wrong here chaps but Grumpy said they are Blade forks RRX ???
So the air gap may be different...
"Firebrand" I blame predictive typing...
So it might be a question better placed in a 'Firebrand' forum
MacV2 wrote:Er correct me if I'm wrong here chaps but Grumpy said they are Blade forks RRX ???
Flatline
Post by Flatline »
You need to check the air gap in your head, Stuart, Firebrand ffs
grumpyfrog
There is no air gap in my knocker, full of rum..
Don't hassle me
adyf
Post by adyf »
Yeah and it's some real quality shite as well
Having played with various air gaps on USD Blade forks I've tried some internet-recommended air gaps, the opinions on various forums seem to vary quite a lot, and not much consensus.
I tried a 90mm air gap but it's like riding a road drill, 110 seems ok but I haven't yet tried 120mm.
I've been using 10 weight oil throughout.
I'm currently using 9kg K-Tech springs, gold valves, 110mm gap and 10 weight oil.
But I expect with a bit more playing about it could be improved a little.
What I don't understand is why people don't just try different settings- how long does it take to whip the wheel off, mudguard and legs, then drain and refill with another setting?
That way you end up with something that suits you and your riding style,useage etc, not to mention body weight.
For example, i like to sit forward, keeping lots of weight over the front end. It works for me, but other riders prefer to get their r's back on the seat, and keep weight over the rear. You'd benefit from different fork setups- quite a bit of difference actually, with both choices.
I spent a weekend draining and refilling rwu Storm forks five or six times to get an air gap that i liked, then tried different weight oils at that air gap.
Time well spent.
But then I sold them and stuck on some Blade USD ones, back to square one.... :?
speedytractor
Post by speedytractor »
Don't see why your fixing it. You not use it again until next year
Sent from my iPad using Tapatalk
grumpyfrog
Ram it up the pair of you.
Bloody BMW gits, go get your slippers out..
S'Tractor- not seen yours out this year you ass whipped Pussy, ARE you getting out?
Don't hassle me
speedytractor
That tractor is usually that glimpse on the horizon. Keep up.
