Out yesterday and the storm developed an anoying problem of cutting out at traffic lifghts - she was doing it on a regular basis.
I've got a set of wolf cans and she never had this problem before, the tickover is about 12-1300 rpm. Apart from that she was running fine.
It was bloody cold - could it be carb icing? Or is the tickover a bit low.
She had a service last week.
Any suggestions.
Phats!
Storm stalling and tickover speed
If it's yellow you should see a doctor!!!!
Thanks Pete
I've looked at the receipt and it says that the carbs were balanced - the plugs wern't changed (It was a 4000 Mile service)
Been looking on the different threads and found one on a similar problem.
The solution may be to use pro boost during the colder weather - is this something that you've used and do you use it all year round as well as the winter.
Greg
Greg
- Pete.L
I've not used Pro Boost but I have been using HarlyDavidson Idle Boost for the last month plus a hotter grade plug. I still get the odd stumble (normally when half warm) but cold starting is no probs .
If the bikes been struggling in the cold the plugs might be a bit tired and need changing even if they haven't done the miles.
- Skatrekker
Doh!
My VTR had been stalling at the lights etc even when warmed up so I upped the tickover speed to 1100-1200 rpm. This worked for a while but last week I was setting off on a 200 mile ride when it started running on one pot. Stopped at the roadside and found the front exhaust was cold. Whipped the plug lead off to check spark, plenty there. took plug out and the electrode had completely burnt away ! After a slow ride home I put a new Splitfire plug in and it ran well. Started off again and no further problems. MPG was better too.
