Big bird
Re: Big bird
lloydie wrote:Image
Yep .
Just need to fit a smaller rear master cylinder now to get more travel and feel from the rear brake .
The new brake pipes look the part Lloydie :thumbup:
I'm guessing you have done away with the ABS, didn't you like it :?:
Re: Big bird
sirch345 wrote:
lloydie wrote:Image
Yep .
ABS !!
CBS = combined braking system .
Yes I've binned it for more than just wanting to separate the brakes .
There was a fault with it that I couldn't repair without spending big money so delinking was the simplistic option .
popkat
Re: Big bird
Post by popkat »
So by delinking you've now got 2 piston front calipers as the middle piston is blanked off, can't see a problem with that they'll still work well... But on the rear you have 2 lines so all 3 pistons are working when originally only the outer 2 worked off the rear master cylinder, why no just blank the middle piston with no brake line and run one line, your master cylinder will work as intended then.
Big bird
Because the rear master powered all 3 large Pistons, 1 at the rear and 2 at the front
Now its only powering the 2 small and 1 large all at the reAr
It's pumping to much fluid hence no lever travel .
The storm one will fit with a little mod to the hanger , as its smaller i should get lever travel and some feel in the pedal .
Re: Big bird
lloydie wrote:
sirch345 wrote:
lloydie wrote:Image
Yep .
ABS !!
Oops yeah CBS, my mistake, a big difference between the two.
I've not really had much to do with bikes with a CBS hence the question, although I have never really fancied the idea, may be it's intended more for touring two up loaded up with luggage. I have heard of some doing what you've done, but not for the same reason as you :wink: Once you get the rear brake sorted I'm sure the new set-up will be fine,
Re: Big bird
Got a little nippy this morning on the ride to work .
With the temperature due to drop over night I thought it best to get some heated grips
Image.
Only took 30mins to fit , they get hot fast ,let's hope they last a few years as I was crying parting with £80 for them :-(
Re: Big bird
hope you glued them on well............ don't want the grips moving as you wrestle the big girl to the ground
Re: Big bird
AMCQ46 wrote:hope you glued them on well............ don't want the grips moving as you wrestle the big girl to the ground
No not yet .
Want to test there position first ,especially the throttle side ,
When I'm happy then I'll glue them on .
Tbh the bird is light when it's on the move and the tyres have 42/42 psi in them :-)
NZSpokes
Re: Big bird
Post by NZSpokes »
Wow, they are $100 here.
All or bikes have them, great things.
darkember
Re: Big bird
Post by darkember »
lloydie wrote:Got a little nippy this morning on the ride to work .
Image.
Solid brand mine are still working fine :thumbup:
Re: Big bird
NZSpokes wrote:Wow, they are $100 here.
Cheap as :-)
You can get very cheap over here but I wanted the best and had to bite the bullet
NZSpokes
Re: Big bird
Post by NZSpokes »
Cheap as :-)
the Oxfords are $100 here, we get them as cheap as $60.
Re: Big bird
While browsing the net I found this black bird and I must say I like it a lot .
I now have the itch to mod the crap out of it once piggy is finished .
My new plan is
Rsv usd forks with a 5 spoke brembo wheel and brembo brakes.
Cb1300 5 spoke rear wheel
Blade brace welded onto the swing arm
Cb1300 rear caliper .
1998 blade rear seat unit .
Rsv ohlins rear shock .
Rear sets .
Why the wombles can't I leave things alone [SEE-NO-EVIL MONKEY][PISTOL]
Re: Big bird
now I can see why you want to do that, it will be a beast...... and you sill still be finished before Flatty gets the Ducafe done
grumpyfrog
Re: Big bird
Post by grumpyfrog »
Tidy, but would look like Crap with the top box on!
Finish Piggy, then see if you have any time! :lol:
Don't hassle me
I'll get there at some time
