tank bolt
Moderator: VTRDark
10robbo
tank bolt
Post by 10robbo »
rear fuel tank nut and bolt needed please
Re: tank bolt
http://www.ronayersmotorcycles.com/fich ... veh=132082
https://www.davidsilverspares.co.uk/par ... rt-number/
It's a common Honda part - and the nut is a bog standard 10mm 'un. Just get the part no. from Ron Ayers and either paste it into DS find by part no. or google it for other suppliers.
10robbo
Re: tank bolt
Post by 10robbo »
thanks I,ll do that now
Re: tank bolt
The thread goes.
Cut off the threaded part, drill a hole down the end and tap it.
Then insert an M6 bolt, cut the head off.
Job done.
10robbo
Re: tank bolt
Post by 10robbo »
thanks that's a good idea as the postage is more than the bolt
