this is going to be discriptive im afraid, forgot to take pics
anyhoo, i had the powrbronze set up and as i sai i didnt like it much as the lights were pants, and to adjust aim or change bulbs it was a fairing off job plus the fact that after a week of being on there the chrome light rings had started to rust through.
So i started thinking and came up with this solution that worked! thanks to Jamoi again
I got hold of a damaged headlight unit for pence, making sure the reflector unit that the bulb fits in was ok.
I bolted the light shells together and offered them up to the reflector,marked round and cut the centre of the reflector out being very careful not to damage the fixings on the back, so the light shells sat inside the outer rim of the reflector and about 5 mm proud at the front.
To allow the back of the headlight unit to fit properly i cut the shells down to about a 10 - 15mm ring and around the bolt holes on either side, then glassed the rings into what remained of the reflector.
Then i took my standard headlight off, and opened it up, popped off the reflector and cut two holes in the back of the unit so i could access the bulbs when it was fitted, fitted the modified reflector back into my original unit and stuck the light units into their shells, refitted the lens and sorted the wiring, they are wired in parallel through two 30amp relays with a direct battery feed fused at 20amp the relays are activated by the old headlamp connector.
This way means that i have the use of the original aim adjusters, the headlight is still a sealed one piece unit, and you only need to connect 4 wires, earth,battery feed to relays,and high and low beam to the old light plug!
hope this gives you some idea, if anyone wants i could take some pics but id have to take the fairing off also if anyone wants this done, i could do it easily, i would just need a donor headlight and the new light units, thinking about it i could do it as a straight plug in mod
B man's headlight conversion
Re: B man's headlight conversion
What light units did you use? From another bike?
I find on my bike on low beam I cant see through turns as there is a sharp cut of light due to the reflector shape, does this resolve that?
The light units are the 4 inch ones you can get for street fighters etc.gives a much better light spread and high beam is very good
right banana your just going to have to do it all over again this time with pictures
Lol ill take a few pics in a bit I need to sort the wiring properly anywaymacdee wrote:right banana your just going to have to do it all over again this time with pictures
- agentpineapple
wiring, I thought it was spaghetti..........Bananaman wrote:Lol ill take a few pics in a bit I need to sort the wiring properly anywaymacdee wrote:right banana your just going to have to do it all over again this time with pictures
thats a spicy meatball eh?!
Good man I can see an increase in used headlight sales now. Quick grab them while you can before the price goes up even more on them.
I think you have done a fantastic job with them lights. It's gotta be one of the best twin headlight conversions I have seen. It actually look OM and suits the bike, kinda an interpretation of an SP but with round lights.
Cheers carl fraid you'll have to wait for the pics, it's chucking it down here
