Breather pipes, how many?
- grinner1969
Hi all, question on how many breather type pipes there should be hanging down from the engine area. This is how it went---- It's something I had taken much notice of until today. Went out for a run and needed to fill up (as usual ), pulled into the filler station next to the pumps, (not looking at the floor as I pulled in), filled up, went in and paid, came back out, keys in, started her up, gloves on, leg over ( ) don't know why, but looked down, only to see a breather type pipe on the floor just behind my front wheel, so got off and picked it up, looked at the front area, there are 3 pipes hanging down, 2 thicker ones and 1 thinner one, the one I picked was the same size as the thicker ones, basically, is this one of mine or has someone else dropped it off?
Re: Breather pipes, how many?
Let's see, there's two from the tank, one from the coolant reservoir, er, that's it. I think.....
Isn't there also one from the thermostat housing? although IIRC the very early Firestorms only had a hole in the housing with no drain off hose,
1 from front of water pump housing?? Or not?tony.mon wrote:Let's see, there's two from the tank, one from the coolant reservoir, er, that's it. I think.....
You're right, early ones had a 90 degree spigot that came off of the front of the crankcases in front of the water pump, and a thin pipe on some bikes runs from that to exit along with the other drains.
Later ones merely have a hole, and nothing dreadful happens, so I take them off earlier bikes; there's no need for them to be there- so that's why I couldn't think of it....
Not....that is an overflow for if the water pump mechanical seal fails.1 from front of water pump housing?? Or not?
3 pipes as Tony said should be hanging down by the gene cover. Have a look under General Information in the workshop manual page 1-22.
Sure mine has 4, as the one from the water pump housing is in a clip above the starter motor and exits by gen covercybercarl wrote:Not....that is an overflow for if the water pump mechanical seal fails.1 from front of water pump housing?? Or not?
- grinner1969
Thanks for throwing that spanner in the works Carl
Any body got a pic as to where their pipes hang down
I ain't going into the cave to check nowgrinner1969 wrote:Sure mine has 4, as the one from the water pump housing is in a clip above the starter motor and exits by gen cover
if you been out for a run I guess you would need a breather?
I also say there is one from the water pump housing, although I called it the thermostat housing in my previous reply. The reason I think there is one there from the mechanical seal is that mine used to weep occasionally down by the other pipes that exit in front of the alternator cover. As I said above, I don't think all years had this pipe. I thought it was the very early ones that only had a hole with no hose, but I see some say different
, helpfullumpyv wrote:if you been out for a run I guess you would need a breather?
Watty wrote:, helpfullumpyv wrote:if you been out for a run I guess you would need a breather?
well its late innit
I stand corrected there is indeed a water pump drain on later models. It's in the manual too.
- grinner1969
Thanks Lump
