A cautionary tale!!
Flatline
A cautionary tale!!
Post by Flatline »
Lot's of advice on here about maintenance
One area that most will shy away from will be the swing arm
The "wise ones" suggest checking the bearings once a year
Whilst this may be a bit much for most, perhaps 5 years would be a good idea
Certainly not 16 years as is the case with mine!!
Shock linkage bearing
I had to cut the bolt to remove the linkage from the swingarm
Then use a socket to drift out the bits that didn't fall out!!! :eek2 :eek2 :eek2
almightytomo
Re: A cautionary tale!!
Post by almightytomo »
Planning a bit strip down and clean up this winter.
Guess this needs to be on my list of Jobs!!! 8O
They will be alright...bit of T-cut will sort it out no Wocking Furries... :lol: :lol:
Flatline
Post by Flatline »
:Ball Kick:
bsabloke
Post by bsabloke »
Mine came out in similar condition. 1 complete bearing, 1 multiple piece. Shaft scrap bolt damaged, seals scrap. I priced all parts from local shop (via honda) around £50. Complete unit £140 8O 8O .
rob de hoo (vtrdh on forum) could source genuine parts for a better price. His website http://www.exhausist.com
i was changing swingarm for a painted black one. Only cam across it by chance. Posted at the time on here & facebook
no happy endings for anyone. Many similar stories & pictures 8O :roll:
yikes, that is one of the worst ones I have seen.......... that's what you get for doing your maintenance on the same slow schedule as your café racer project :wink:
Shame on you, if you're responsible for that :crazy:
simo
Post by simo »
Every other year for mine. You Lads who ride all year and through the winter months it should be an anual thing.
Theres A Hare in The Turnips.
Flatline
Post by Flatline »
AMCQ46 wrote:yikes, that is one of the worst ones I have seen.......... that's what you get for doing your maintenance on the same slow schedule as your café racer project :wink:
:Ball Kick:
Flatline
Post by Flatline »
:Finger: :Finger: :Finger:
sirch345 wrote:Shame on you, if you're responsible for that :crazy:
Flatline wrote::Finger: :Finger: :Finger:
That's a bit strong. Chris must be the politest person on this forum, so polite it's in-polite :lol: I'm guessing he was thinking that you should know bloody better. Well, maybe not the bloody, but I will add that in as I was thinking the same :biggrin
Flatline
Post by Flatline »
Oh, ok then, you're right :lol: :lol: :lol:
