Chain tensioner broke, do i remove metal plate?
Hvornum
Post by Hvornum »
Hi!
First off, thank you for this lovely guide: Manual Cam Chain Tensioner Installation Guide (MCCT's), it really pointed out 99% of the problems i've had with localizing a issue with noises from the engine when the old tensioner broke..
Anyway, I've stripped down the bike.
I've realigned the inlet on the front cylinder because it was off by ~15 degrees (and hopefully the valve hasn't taken any damage, will check tomorrow). That sad, I'm wondering if i should remove the metal plate gripping on the chain or if that's a part of the chain all together..
The part being the one visible in the hole where the old tensioner reside:
It's like a metal jacket grabbing over the chain with a small metal nob/circle on top of it, is this a part of the old tensioner and if it's supposed to be removed how do you go about doing it?
Cheers!
Jscobey
Re: Chain tensioner broke, do i remove metal plate?
Post by Jscobey »
thats the blade which is actually what the tensioner presses against the give to chain the desired tension. leave it there.
Jscobey wrote:thats the blade which is actually what the tensioner presses against the give to chain the desired tension. leave it there.
+1 :thumbup:
Hvornum
Post by Hvornum »
Perfect, will do! On to building it all together in other words :)
+2 :thumbup:
On the other hand I'd love to watch you try to pull it out through that little round hole.... :lol:
If it's only one tooth out you may well have got away with it, but stick a new one in and see how it feels.
Not a new Honda one, obviously...
