Front brake pipe extention kit
I need to extend the front brake pipes . is there a two into one pipe adapter kit available.. ? any suggestions for doing this on a budget...? thankyou guys
Re: Front brake pipe extention kit
If there is such a thing I wouldn't bother using it. Just another thing to worry about if the brakes go spongy. Better off just buying longer lines and be done with it
Sent from my HTC One using Tapatalk
my front brakes have one line to the lever and go into a 2 into 1 splitter/manifold type of thing. I got it all from venhill.
nice quality and they are a helpful bunch
Most likely simpler to order lines the length required but you may be able order the bottom half of the non race kit to extend them if you contact one of the brake line manufacturers.
