IN NEED OF HELP
domdom
IN NEED OF HELP
Post by domdom »
Was going to check cam chains as bike making whirring nose. Got front velocity stack off fine but some muppet has chewed one of the screw head on the rear one, didn't want to do my normal just go and tw@ it with hammer and stuff the job totally. Any ideas how to get round this be great...... Or can just leave it till 26th for the workshop day...... :confused :confused
mattycoops43
Re: IN NEED OF HELP
Post by mattycoops43 »
Got a dremel? I normally re slot screws like that.
domdom
Re: IN NEED OF HELP
Post by domdom »
bugger hadn't thought of that......
darkember
Re: IN NEED OF HELP
Post by darkember »
mattycoops43 wrote:Got a dremel? I normally re slot screws like that.
Yes will work fine had to slot out the carb bowel screws the other day as 3 of them had chewed up.
Re: IN NEED OF HELP
Make sure you bung up the inlets so not to get crap down there when your cutting away
domdom
Re: IN NEED OF HELP
Post by domdom »
Nice one, jobs a good'un why do some people have to over tighten things so much, i'll never know........ best get on with the job now...... may need help with engine rebuild lkater, if all goes pear shaped..... :lol: :lol:
Re: IN NEED OF HELP
For those without a Dremel a junior hacksaw will also do the trick.
Just undo the internal pipework and get it out of the way first.
domdom
Re: IN NEED OF HELP
Post by domdom »
Well after what probbaly was to much tea drinking and fag breaks, the old girl is up and running again. about 6mm of play in cam chain now, instead of the 4mm that was sounds better and starts better. So good job alround i recon..... :thumbup: :thumbup:
Re: IN NEED OF HELP
You made a good move slackening them off by the sounds of it. I wonder what else you will find overtightened. Seems to be a theme going on here.
domdom
Re: IN NEED OF HELP
Post by domdom »
Pretty much all good now, can't be much else to do..... got the suspension sorted last year, done the rear linkage with grease niples, swinging arm bearings pistons and seals in front and rear brakes, also serviced the master cylinder........ so bike is now covered in white dots of tipex on most of the bolts :lol: :lol:
Re: IN NEED OF HELP
Don't make the dots too big or you bike will look like a Dalmatian. :lol:
