As it says above. I'm not confident that mine is collapsing or a bit blocked (it's the cause of all my recent woes). I want to be sure I have the right, and functional new part. The Ron Ayers fiche wasn't that clear.
Can anyone help?
Part number - vac pipe - rear carb to tank
- cliveyandrews
- Contact:
![Image](http://www.clivey.com/images/Sig%20pics/MonkeyPic.gif)
Audi, Vide, Tace
Audi, Vide, Tace
Re: Part number - vac pipe - rear carb to tank
5mm ID should do the trick > http://www.ebay.co.uk/itm/1-Metre-Silic ... 2a174f1dc6
I can't remember if it's 5mm or 4mm
http://www.ebay.co.uk/itm/250439149810? ... 26_rdc%3D1
- cliveyandrews
- Contact:
Blinder. David Silver don't stock 'em. Cheers.
Audi, Vide, Tace
Audi, Vide, Tace
- cliveyandrews
- Contact:
2m of Silicone stuff ordered. Hopefully I can run the tap from the rear carbie and T it for vac gauges. Then just block the front. At the moment both are T'd together then onto tap.
Audi, Vide, Tace
Audi, Vide, Tace
- cliveyandrews
- Contact:
Well, stripped it all down, the 5mm hose don't fit - too loose. Looks like I need 4mm, will order some tomorrow. Did tweak the TPS while it was apart, managed to get it to just over 600 Ohms on standard slots, so while I have it apart again next weekend I will Dremel the slots back a bit! 'Stormy running well though!
Audi, Vide, Tace
Audi, Vide, Tace
