Page 1 of 2
My Efforts Finally Bare Fruit
Posted: Sun Mar 09, 2014 4:28 pm
by darkember
This has been a labour of love & I'm only halfway there
However I do like the results thus far
The process thus far:
Removing the paint the hardest job:
Paint removed ready for sanding
Sanding done down to 3000 wet & dry:
Finally the polished item next to the original:
Now all I need to do is apply the heat resistant lacquer. Does anybody have any tips on this job:
1: How many coats should be applied?
2: Should I cure each coat before applying the next?
3: How long should the curing take?
4: Can I cure them in my oven & at what temperature?
Re: My Efforts Finally Bare Fruit
Posted: Sun Mar 09, 2014 4:47 pm
by Ckennedy
Good work
it is looking good. Grab yourself a pint for half a job well done
![beer :beer:](./images/smilies/beer.gif)
will look good when there both shiney
Posted: Sun Mar 09, 2014 4:54 pm
by agentpineapple
Posted: Sun Mar 09, 2014 7:50 pm
by kenmoore
Bling bling!
Looks good!
Posted: Sun Mar 09, 2014 7:56 pm
by Wicky
Posted: Sun Mar 09, 2014 9:55 pm
by Da Lipper
That looks great! How long did it take to rub down?
Posted: Sun Mar 09, 2014 10:30 pm
by darkember
Da Lipper wrote:That looks great! How long did it take to rub down?
3 hrs from 600 - 3000 grit & double polish paste brown & blue. That was the easy bit. 5 days to remove the paint that is the hard bit dreading the next one, but it has to be done.
Posted: Sun Mar 09, 2014 10:34 pm
by Kev L
Nice work fella, that looks very trick
Posted: Sun Mar 09, 2014 11:00 pm
by VTRDark
Those polished cam covers (polished cam covers to make it searchable when I want to find the thread
) Look fantastic. I likey very much. You have done a great job there and a labour of love indeed. How's your finger tips
As for the laquer double check the manufactures directions for whichever product you end up using. I would double check the heat resistance on that paint wicky posted.
Personally I would use at least a whole can on both covers, that's one can between the two so half can each. Do them both side by side at the same time to minimise waste. Lots of thin coats is better than less thicker coats. Leave to go tacky between coats, say... spray coat, leave for 10 mins and then do the next coat, leave for 10mins, next coat and so on.
Leave enough spray in the can for one more thin coat! Leave them to cure for at least 24h or however long the manufacturers instructions say. Then give them a rub down with some fine wet n dry, 800 grade to de-nib any imperfections and get rid of the odd run you may have got. Wash down and dry, tack rag and give a final coat of paint. Allow to fully cure for a little longer than before. Best to leave as long as you possibly can, a week if needs be and you have the time. Then get some 1200 grade wet n dry, rub down so you loose the shine and get the cloudy look, then polish (cutting compound) to get the shine back.
Perfection
I might be wrong, but like I say check the manufactures instructions. I would not go putting them in the oven. There will be enough heat getting into them from running the engine and they will harden up more over time.
Oh and you are using the we n dry wet with plenty of warm soapy water arnt you?
Posted: Mon Mar 10, 2014 5:16 pm
by darkember
cybercarl wrote:Those polished cam covers (polished cam covers to make it searchable when I want to find the thread
Perfection
I will be using "Hycote VHT Clear lacquer resistant up to 450 degrees C.
I'm not sure if I should be rubbing this stuff down after application as this is the final protective coating wont I just be removing what I have sprayed on?? Remember I have already done the wet & dry to 3000 & then buffed with 2 polishing pastes
Posted: Mon Mar 10, 2014 7:00 pm
by VTRDark
I hear what you saying about the wet n dry to 3000 (god that is fine) 1200 or 1500 is is what is normally recommended for the final rub down before polishing paint. Lacquer/varnish is just paint without the colourants! It's down to how good/smooth a finish you want. The smoother the finish the less light that is scattered. It's the less scattered light that gives a mirrored finish.
After spraying it wont be as smooth as 3000 anymore no matter how good a sprayer you are. That does not mean that what you have done is a waste of time though. The better the prep the better the finish
Ideally one would wet n dry and tack rag between every coat. If you think about it your going to spray on a perfect surface at the moment so as it dries the paint flows and finds it own level to a degree, depending on how even a coat you apply. if it's not rubbed back down after and then one applies another coat, say without tac ragging as well, so there are dust contaminants to deal with also. The paint then sits on top of those inconsistencies of highs and lows (like on a CD or hard drive platter 0's and 1s
) If it's rubbed back down as smooth as glass and perfectly clean and you apply the paint, your then getting a more consistent even coat.
The way I'm talking is doing it to perfection by the book. IIRC It takes 3 months for the painter to paint number 10's front door to that mirrored gloss finish. Obviously not everyone has that time to get 100% perfection so one does as best they can within their time-scale. I don't expect you to go to that degree of finish, but considering all the effort you have put in so far, I wanted to make you aware of how to get a good paint finish that gives you that mirrored look.
As I said though follow the manufactures instructions for the paint, application, drying times etc. I hope it does not yellow over time as some paints/lacquers can do. I'm trying to think of another way that you can protect your finish so it does not oxidise but don't know of anything that can withstand the test of time and heat.
Maybe Chric knows of a detailing metal polish that protects from oxidization and discolouration. But you want something that lasts pretty much forever and is heat resistant otherwise it's like rearsets and one has to keep on top of it with Autosol or equivalent.
Oh and I should add in response to your question. Yes you will be taking back off what you have previously applied but we are talking microns as a scale of measurement/paint thickness. You taking off the highs/roughness from the previous coat to get it back down to a that perfectly smooth as glass (or baby's elbow LOL) surface ready for the next coat or finish.
Hope that makes sense
Check out the vids in the following thread
http://www.vtr1000.org/phpBB3/viewtopic.php?f=7&t=26166
Posted: Mon Mar 10, 2014 7:51 pm
by Jamoi
Would natural (clear) anodising work?
Posted: Mon Mar 10, 2014 8:03 pm
by darkember
Thanks Carl makes sense now
Posted: Mon Mar 10, 2014 8:09 pm
by VTRDark
Can you get a clear anodising then. Not heard of that before. Why arn't we all doing that to out headers then. Is anodising heat resistant.
Posted: Mon Mar 10, 2014 8:38 pm
by tony.mon
You could chrome it.
