Painting wheels/sub frames
Damon777
Post by Damon777 »
Hi all, I am giving the (super fast red storm) a bit of a winter make over and needed a few pointers. The wheels are gold and I want them re-sprayed gold as they are starting to bubble with corrosion in places, I have spoken to the local shot blaster workshop who can do them £60 per wheel. Someone told me I will need to get the corrosion acid etched after shot blasting and before painting to prevent corrosion coming back ? The guy at shot blasters said he doesn't do this with the wheels he does. So is acid etching a bit over the top ? or will the corrosion soon come back after painting ? . I am going to have sub frame and small fairing frame painted as well. While I am here asking questions is there any special tools needed to replace fork seals ? Cheers :beer:
Bleh
Re: Painting wheels/sub frames
Post by Bleh »
Haven't done forks on the VTR myself yet, but you should be able to do the job with your standard set of garage tools with a cir-clip pliers being about as specialist as you'll need...
As for your wheels, all I can do is recommend the guy who painted and baked my old cbr wheel. It had a polished rim with signs of the weather on it (winter riding!!). Had him colour match it to the wheel being replaced to perfection and he charged me little over £60 for the lot and the wheel has dealt better with being used than my powder coated other!
He's a perfectionist to be fair to him and a nice guy too, likes his bikes (and his cars).
You'll have to post to south wales though but could still be cheaper than what you're looking to pay locally.
http://www.alloyrefurb.net/Pages/default.aspx
If that doesn't work, search for APS polishing swansea. He's a one man band so doesn't have a business elsewhere!
I'm not death to power tools... If it breaks, it's obviously NOT a power tool!!!
macdee
Post by macdee »
hi no special tools needed to do the forks
use the old seal to push the new seal into place just grind the outside down a bit to make it smaller
use good quality allen keys to loosen the allen heads on the bottom of the fork leg :thumbup:
Damon777
Post by Damon777 »
Don't use allen keys, they could twist out.
I'd suggest investing in a set of hex bits, long reach, like these for example, although this set also has anti tamper and star drive bits as well.
Someone posted a cheap set in here somewhere- I bought one, they work fine, less than a tenner the set IIRC
