Headlight bulb upgrade!
Can anyone advise me what the largest wattage headlight bulb is I can run without any problems and major mods?
Re: Headlight bulb upgrade!
Stick to H4 -60/55 W - unless you put a ceramic bulb holder in (to replace standard meltable OEM placcy/nylon one) / Eager Beaver Relay kit.
Cheers Wicky Where would the best place be to source all that?Wicky wrote:Stick to H4 -60/55 W - unless you put a ceramic bulb holder in (to replace standard meltable OEM placcy/nylon one) / Eager Beaver Relay kit.
http://www.easternbeaver.com/Main/Wirin ... _kits.html
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
With all that don't push it with silly wattage bulbs as things can still melt!
Nice one , was thinking along the lines of 100w? What do you think and will light lens be ok?Wicky wrote:http://www.easternbeaver.com/Main/Wirin ... _kits.html
no you will get condensation build up and it will ruin the lens (i know as it happened to me ) just used the normal buld and fit a relay kit . or fit a projector + HID kitWatty wrote:Nice one , was thinking along the lines of 100w? What do you think and will light lens be ok?Wicky wrote:http://www.easternbeaver.com/Main/Wirin ... _kits.html
Careful if you have it on main beam too long…
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=16761
I have a 55/100 with relay kit in mine, no problems with that as it is normal rated on dip beam
AMCQ46 wrote:I have a 55/100 with relay kit in mine, no problems with that as it is normal rated on dip beam
here too... works like a charm!
Is that with ceramic holder?mik_str wrote:AMCQ46 wrote:I have a 55/100 with relay kit in mine, no problems with that as it is normal rated on dip beam
I'm running with a 100/55 so I have a better high beam when needed. Fitted 6 months ago, plugged straight in and no issues.
No, I bought the normal relay kit with plastic holder, I didn't spot the ceramic one back then when I did the conversion. No sign of problems on the connector last time I had the fairing offWatty wrote:Is that with ceramic holder?mik_str wrote:AMCQ46 wrote:I have a 55/100 with relay kit in mine, no problems with that as it is normal rated on dip beam
- Saintsman27
A member posted these bulbs earlier in the year .. cheap enough.
http://www.ebay.co.uk/itm/230763060244? ... 1423.l2649
Wonder if anyone has tried them? Not got any faith in Chinese productsSaintsman27 wrote:A member posted these bulbs earlier in the year .. cheap enough.
