Pete.L wrote:I tend to agree.
The only other senarios I can think of are to do with where you took your DC feed from and what route the cable take on the way to the headlamp.
I'm thinking
A) could your supply be floating(not regulated by the bridge retifier)
B) if the cabling was too close to your HT leads could you be inducing AC spikes into the lighting circuit and destroying the bulbs.
Engine running. Check for any voltage between the rectifier earth and the battery earth. There should be none. Then DC levels across the bulb and then from the battery negative and feed side of the bulb. Make sure you have the same rpm for both. About 3k should be enough.
You could try to see if you have any AC between the bulb and battery earth as well but I wouldn't expect any if everything is okay.
Report back and we'll se if we can make any sense of it.
Or just take your mod off and drive a little slower in the dark ya crazy bugger
Well, good creative thinking all of the above... Buuut... If he manages the feat of having the supply floating, or getting AC spikes in to it, by any means of creative wiring, it still boils down to a single cause in the end... Defective R/R... Plain and simple...
The R/R takes three AC wires in, and two wires out, one ground and one positive... There is no amount of creative wiring that can bypass the R/R, unless you hook something directly to that stator by those three wires, which I highly doubt he has done... As for floating, yeah, he "could" have a floating ground, but that would also mean that his bike wasn't charging, since he cannot manage to disconnect both the R/R ground from the battery ground, and the bulb ground from the both of them, not without the bike going entirely dark... And even if he did, that could never amount to a higher than normal voltage over the bulb anyways, only lower...
So, either the R/R is defective, with one of the three diode phases always conducting (at least partially), and spiking voltage above normal when it's overlayed on the other two phases... That happens, usually, but not always around 4k+ revs, on a stock Honda R/R, since that's the rev/voltage that corresponds to when the archaic regulator is starting to actually do any amount of work, and changing the dynamics slightly (ie heating the diodes)... Or he has an intermittent short somewhere... Ie works for a while and when you hit a bump in the road, *pop* goes the bulb... Should be the fuse, really, but since he effectively has no fuse, the bulb is the first thing to die...
A fully functioning R/R should never, ever allow anything above 15.4 V through, and should at all times except on low/rough idle with a cold engine, deliver between 13.2 and 14.8 V, and very rarely go outside that...
