Have any of you got the complete front engine mount bolt plus all the little bits to go with it? I find myself in need of one.
Let me know if you do and how much inc postage
front engine mount bits
Moderator: VTRDark
Re: front engine mount bits
As a temporary bodge three or four years ago I used a length of M12 stainless studding and nuts.
I replaced it with a std Honda bolt and adjuster earlier this year.
It was fine, and of course didn't require industrial steam hammers or an angle grinder to remove it.
And about a tenner all in, with the washers.
Not a bad idea tony bit I may as well do the job right first time. Not in a mojor rush but would like it sooner rather than later. If no one here has one and I can't source a second hand one I'll have to go brand new at the cost of nearly 50quid
Hasn't Lloydie got one in his bag of bits he got the other day.
Yep but that's for miss piggy and is already offered as a loan if neededcybercarl wrote:Hasn't Lloydie got one in his bag of bits he got the other day.
Not sure if I have the top one or not. I'll have to have a look.
I know I moved one the other day but think it may be the rear one...
I think the top one got buggered getting it out...
I'll check later & get back to you.
Mac
Mac
Cheers Mac
Your in luck...sort of.
I do have one, c/w the threaded adjuster bit & a nut (+a spare nut) but I do not have the castle nut.
It's a bit beaten up & is a bit corroded esp at the nut end but should clean up.
The thread at the nut end is a bit chewed up & the nut wont go on atm but re cut the thread & it should be ok.
As it's a bit beaten up I'll send it to you FOC, if you can use it great, if it's no good bin it.
PM me your addy & I'll get it posted asap.
Mac & Franks Spares Emporium. A sub division of Mac & Franks Acme Industries International Corp.
