Hello from Canada
Hello from Canada
Just got into riding bikes beginning of this year. Started with a 2005 Ninja 500 and then upgraded to a 2000 vtr 1000. From all the research I have done this is by far the best forum out there, lots of useful information, so thank you very much. From doing a bit of research I have already learned this bike has the biggest carbs in the industry, however my carb skills suck. The previous owner fitted a KN air filter and some after market exhaust with silencers. I ran without the silencers for a few days, and noticed the bike ran progressively worse. Would stall at sudden stops was the main one, always fired back up. I have since reinstalled the silencers and bumped up the idle, which is my first question, what is recommended for idle ?? With the air filter and exhaust, do I need to jet ? I have heard rich is ok for these bikes, lean is very bad. And I guess my next question would be what is the best way to tell rich/lean ? With silencers out, when I would choke in the morning, it was like it had no affect. Since installing silencers, been better. Sounds to me like I'm hovering on the border line ?
The transmission seems to make almost like a scratchy noise under certain load, applying brakes or clutch has no affect, its really just under certain load. Previous owner said he had a mechanic look at it, said it was fine. I know the CCT's were changed, however do not know if a manual one was put in or just the Honda factory style. Guess the only way to tell is tear it down and do the fail safe mod ?
Re: Hello from Canada
Hello and welcome :-) .
I'd fit a standard (oem or a generic ) air filter back in unless its been set up to run that air filter .
Idle - 1200 rpm seams best on mine
The only real way to tell if its lean or rich is to pop it on a Dyno
Hi and welcome . Yes you've joined the wright Forum. Plenty of knowledge on here and willing people to help out.
Theres A Hare in The Turnips.
- Hairy biker
Welcome aboard justshad
As Lloydie said, a dyno run would tell you a lot. I take it you are referring to the baffles when you mention silencers
they are the short things that go in the end of the silencers to quieten it down (or cans as the silencers are also know as).
Balancing the carbs is also another thing that could help on the cutting out bit, especially if that's not been done for a while.
![Question :?:](./images/smilies/icon_question.gif)
Welcome, i'm a newb' here too, although no longer in .Ca, where abouts are you?
- agentpineapple
welcome to the forum buddy, another thing to consider doing isto rest your throttle position sensor to as close to 500ohm as possible, read thru the workshop section about the cct's, its easy to spot the difference between standard and manuals, manuals have a longish bolt on show , with a nut on theend of it, honda oem cct's look like a minature spaceship....
And how do you know what a spaceship looks like.
A quick welcome from me.
![Big Grin :biggrin](./images/smilies/biggrin.gif)
![beer :beer:](./images/smilies/beer.gif)
Because, like all great men, pineapple loves Star Trek
Welcome![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
Sent from my GT-I9505, written in ASCII using an even parity bit and spoofing the IP of the White House
Welcome
Hi there & welcome. Yes I also find that having the DB killers in the bike it runs better & a little richer as well. The K&N filter will have a dramatic effect if the carbs have not been jetted to suit. As said before try the stock filter with the db killers in & see what it feels like. If it performs worse then it is a sign that the carbs have been jetted for the K&N. In many cases it will run better as plonkers just throw the K&N on thinking they are going to get an improvement; in reality without doing the whole shebang its not worth it as the bike will run badly. The dyno will tell you whats what if you can swallow the bucks for it.
Welcome, it's the rite place to get help and advise!
Welcome to the club fella
Right now in Edmonton Alberta. Im not too sure what we have here available for a dyno. To be honest, I havent even opened the air box to confirm it is a KN filter. Just basing that on what previous owner told me. Being it is the end of August, riding season is almost over. Plan to purchase jet kit over winter, just not sure as to what stage will be required. If i had to guess, between the pipes and air filter, a stage 3 would be recommended. But no way to tell till I pick one and start.
I will do TPS sensor mod, but going in kinda blind. Its hard to mod something until u know how it works. This bike is carbed, so it's not being run by a computer, can anybody explain a lil bit more indepth as to what changing the values does exactly ?
Exactly, baffles. We call them silencers.sirch345 wrote:Welcome aboard justshad![]()
As Lloydie said, a dyno run would tell you a lot. I take it you are referring to the baffles when you mention silencersthey are the short things that go in the end of the silencers to quieten it down (or cans as the silencers are also know as).
