List of required parts...
Moderator: VTRDark
Thinking more on my Euro trip I have realised I need to make some adjustments to the bike and acquire some more bits before I go. In order of urgency which I need:
1: brighter indicators (original storm or after market, front and rear) May have some sorted but pipe up anyway. Would like flush mounts for front
2: Rentect luggage rack. I have the mount bars just no grab rail with luggage rack.
3. Headlight beam adjuster lens.
Could do with them ASAP. Planned trip in 2nd week of Sept.
I did have other things in mind but now I have come to list them I have forgot all of them Will add them if I remember.
Thanks in advance
Chris
Thanks in advance
Chris
Re: List of required parts...
Baby wipes is a must
Renntec in the ebay thread
Remember you can borrow my rack if needed
There are adjusters for up/down & left/right on the back of the headlight.Headlight beam adjuster lens.
Hope you've got spare wine carrying capacity for the return trip
And don't bring back any immigrants.
[youtube][/youtube]
[youtube][/youtube]
Garry Garry ! That's one of my favourite episodes
Do I just need to change it to point left then? or is there more to it?Wicky wrote:There are adjusters for up/down & left/right on the back of the headlight.Headlight beam adjuster lens.
- Hairy biker
You need to mask off the 'kick up' on the beam pattern, beam benders are the easy option, you can do it with gaffer tape but it can be a bit of a faf about,you'll be able to see the beam pattern against a wall or garage door, then then you just move the beam bender/gaffer tape around until the kick up disappears and your left with a flatline,its much easier to take it to a testing station and use their beam tester to do it.Ckennedy wrote:Do I just need to change it to point left then? or is there more to it?Wicky wrote:There are adjusters for up/down & left/right on the back of the headlight.Headlight beam adjuster lens.
Of all the things I've lost I miss my mind the most
Upper left adjuster - Up & Down, Lower right adjuster - Left & right
Think a lens is an easier option. Anyone got one?
10mm socket , few twizzles & viola beam direction adjusted.
Ckennedy wrote:Think a lens is an easier option. Anyone got one?
It's easy I will show you later .
Just do as Hairy suggested. All that is needed is a triangular shaped bit of gaffa tape or something to block the beam.
http://www.brick-yard.co.uk/vehiclespec ... adlamp.htm
I would juts stick it on so it looks the part. Who gives a sh1t about the beam. If it Blinds the French... well.. wombles um.
http://www.motoring-into-europe.co.uk/faq.html
http://www.halfords.com/webapp/wcs/stor ... yId_165458
Yes, and sun tan oil as the cheeks escaping from the speedos on the Riviera beach will go pink in minutes......lloydie wrote:Baby oil is a must
