rear shock
leelee
rear shock
Post by leelee »
hi all want to replace the rear shock on bike was wondering what shocks I can use and if any other bike shocks will work on it. thanks :thumbup:
ride it till the tires fall off then keep going !!!!!!!
Tweety
Re: rear shock
Post by Tweety »
No, there are no shocks from other bikes that are a direct bolt on... They all have either the wrong fasterners, the wrong length/stroke or entirely wrong spring/valving...
You can get an f4i or 900RR shock and modify it heavily with billet parts, making it longer, and change the valving... Or have it done for you... http://www.daughertymotorsports.com/vtr ... 1000f.html or, you can go for whatever aftermarket option you like, Hagon, Ohlins you name it...
Re: rear shock
Only heard of heavily modified CBR F4i rear shock done in the States as a replacement to the OEM shock.
Try a search for rear shock on this forum and see what aftermarket shocks are recommended
http://www.vtr1000.org/phpBB3/viewtopic ... ck#p276720
E.Marquez
Re: rear shock
Post by E.Marquez »
Tweety wrote:No, there are no shocks from other bikes that are a direct bolt on... They all have either the wrong fasterners, the wrong length/stroke or entirely wrong spring/valving...
Just as a side note... I went this route... as good used aftermarket options at the time were harder to find than hens teeth.
The Reworked F4i shock is a dream to ride... the work and set up so good,,, I just had Mr daugherty set up a set of forks as well.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Re: rear shock
I tried WP base Emulsion type shock and then a Nitron Street shock.............The Nitron is impressive
Tweety
Re: rear shock
Post by Tweety »
Wicky wrote:Only heard of heavily modified CBR F4i rear shock done in the States as a replacement to the OEM shock.
Well... even easier... I gave him a link... :wink:
thumperslaw
Re: rear shock
Post by thumperslaw »
Just got my Hagon shock back
Will be fitting it later and will let ya know
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
