storm won't start
john ps13
storm won't start
Post by john ps13 »
Help.
It won't start once its been running with the headlight on. :x
Starts fine cold same hot. but just a click from the starter relay if the lights been on while riding.
But if I leave it a few hours then it will start again.
darkember
Re: storm won't start
Post by darkember »
First check the connection on the front of the starter, remove it & clean it with a file. If that does not cure it then its a matter of checking each system from the battery through to the charging system. Use the following as a guide:
http://www.electrexworld.co.uk/acatalog ... G-&-RR.pdf
If it's not charging with the lights on it will be a charging circuit problem.
Most likely the reg rec, but possibly the alternator output- one coil of the stator failed, for example.
But my money's on the reg rec, over or under charging the battery. Either way the battery will recover a bit once left to sit for a bit, so meter out the charging voltages and see what you have.
There's a useful guide in the workshop knowledge base.
