Does anyone know if Firestorm wheels fit any other bikes? As a direct fit without custom spacers, that is.
CBR600F perhaps? Or early hornet 900? Just guesses, but much appreciated if anyone who really knows can give me an answer..
Cheers, Dave
Do Firestorm Wheels fit anything else?
- agentpineapple
Re: Do Firestorm Wheels fit anything else?
I believe they fit early fireblades and are used as an easy upgrade to a 17inch front wheel. its also a straight swap for the rear.
seeing as some 6 spoke nc30/35, vfr750, cbr600, front wheels fit the storm, different years for different models tho, so homework is needed to get the correct year/model.
the storm front wheel will obviously fit those models.
the rear wheels aren't so easy to swap because iirc they're a 5.5inch wheel and more modern bikes run a 6inch rear.
The firestorm wheels (all years) are a direct fit (and a upgrade ) for the 1994-1997 cbr900rr fireblade .
The front wheel fits others but not the rear .
There's a list in the workshop knowledge base sticky section that will help a little more
Thanks to lloydie, simo and agentpineapple for your help - appreciated.
Dave
Dave
