Numb fingers!
Numb fingers!
Hi all, anyone suffer with numb fingers on the storm? Done approx 150 mile ride out today and suffered quite badly with it! I know I'm due new gloves( slightly tight ) but never really had too much trouble on my zx6! Bike is fitted with motrax after market bar ends, could it be they are not heavy enough? Cheers, Andy.
Re: Numb fingers!
Maybe its time you looked at your riding posture when on the bike .
Try to have a lighter grip on the bars by supporting your weight by using your lower back and grip the tank with your knees .
This helped me before fitting renthal bars .
Re: Numb fingers!
yep relax your grip.
maybe get some looser fitting gloves. (note i said that before reading thaat your gloves are too tight! its a common thing)
any excessive vibration from the front end? check the brakes arent binding, front wheel balance, wheel bearings....
Re: Numb fingers!
That's basically how I ride mate as far as possible, that's a mistake I used to make in my early riding days! Used to hang on for grim death! :?
Gazfirestormowner
Re: Numb fingers!
Post by Gazfirestormowner »
Yeah I had the same first few rides on mine turns out I was gripping on for grim life gets better as u get used to the bike and relax a bit lol
Re: Numb fingers!
Wattys1 wrote:That's basically how I ride mate as far as possible, that's a mistake I used to make in my early riding days! Used to hang on for grim death! :?
lolz! no need to. make a conscious effort to relax and youll enjoy the ride a lot more and find it a lot less tiring.
you must be nackered after 100 mile???
the bike will more or less ride itself. and the quicker you go the more stable it will be.
Re: Numb fingers!
benny hedges wrote:yep relax your grip.
I wouldn't say any excessive vibes! All good brakes and bearing wise and new tyres newly balanced!
Re: Numb fingers!
I don't hang on any more mate! Just relaxed and enjoy it.
Ckennedy
Re: Numb fingers!
Post by Ckennedy »
You could always raise your bars up the forks 5mm or so and get the later model handle bars. I did this and its made no end of difference.
leevtr
Re: Numb fingers!
Post by leevtr »
I only ever had this once, and that was a sustained run of constant 60 mph ish. I had a hugger strapped to the rear seat that I didnt want to lose, so had to take it easy. That must have been the right speed for the vibes to get me, never happened again.
Re: Numb fingers!
Yes you have to keep your hands lite on the bike.
When you are in your car, do you hold the steering wheel in a death grip or just lightly use you hands or even finger tips to steer with ?
The bike is the same thing. The bars are there to steer with, not hold you up.
When you loosen your grip you also begin to "feel" what is going on with the front tire.
This makes you a safer rider in the long run because the bike will tell you it is not happy, long before you loose the front (in most cases) if you are paying "attention" to your front end feed back.
With a death grip, you hit the ground with no warning what so ever.
getting off the soap box now...... :Smoke3:
Re: Numb fingers!
leevtr wrote:I only ever had this once, and that was a sustained run of constant 60 mph ish. I had a hugger strapped to the rear seat that I didnt want to lose, so had to take it easy. That must have been the right speed for the vibes to get me, never happened again.
We've been stuck around that speed a few times today!!!!!!!
Re: Numb fingers!
They need heavy bar weights or there is a lot of vibration (especially if you stay at one engine speed) so of it has short aftermarket ones then swap them back to the steel Honda ones, or get some heavier ones.....I have some extra heavy ones I was using before I fitted renthals if you want to try them
Re: Numb fingers!
AMCQ46 wrote:They need heavy bar weights or there is a lot of vibration (especially if you stay at one engine speed) so of it has short aftermarket ones then swap them back to the steel Honda ones, or get some heavier ones.....I have some extra heavy ones I was using before I fitted renthals if you want to try them
I would say worth seeing if heavier handlebar weights or originals could help, and as others have said, a lighter grip does make a difference.
I don't know if this would make much difference to handlebar vibration, but when were the carbs last balanced?
geodude
Re: Numb fingers!
Post by geodude »
Other possible things to try that haven't been covered
Do you carry a rucksack? Having the straps to tight can restrict blood flow to your hands.
Ill fitting and new gloves can lead to numbing too. Especially new gloves as you are having to put more effort closing your hands due to the new material being tight.
