autosol
Re: autosol
Probably. Try a small, out of the way area. If it stays white when your rubbing it in, its lacquered. so STOP.
If however it starts going black, then rub
, rub, rub and rub some more till ya fingers sore. Then rub more.
or cheat and get a nice felt wheel for a drill. Mind the spatter though.
Sent from my HTC One X using Tapatalk 2
Re: autosol
Will do mate, thanks.Eclectic wrote:Probably. Try a small, out of the way area. If it stays white when your rubbing it in, its lacquered. so STOP.
Re: autosol
Yes it will do the polished bitsscouse645 wrote:Just a quick question, i got some autosol to clean my exhausts, can i use that on the frame? as my frame is a polished one just thought i would ask.
- agentpineapple
Re: autosol
a dremel or rotary tool is good to use on those awkward nooks and crannies. for best results with autosol, you need to use a power tool, autosol's at its most effective when used at speed.
have fun with that....
Re: autosol
Marty is quite right. Luckily i have access to such machinery through my day job.
Bit ffs dont use ya dremel on the main bulk of the frame. It polishes unevenly and takes a lot of skill to blend it evenly due to the of the tiny head.
i personally use a 2" felt wheel on a variable speed grinder (polisher)
Re: autosol
Cheers for all the info, just have to get more confident for some of these jobs,
Re: autosol
Gerron with it, lad
