Manual Cam Chain Tensioner Installation Guide (MCCT's)
Shibby46
Re: Manual Cam Chain Tensioner Installation Guide (MCCT's)
Post by Shibby46 »
alanfjones1411 wrote: Tue Dec 01, 2020 6:43 pm I don't know what causes carb farts,but it sounds like a thump under the fuel tank.Nearly all Vtr's suffer from it.Mine used to do it before it warmed up properly.
This is all making me feel better, I was starting to panic about my mccts, though I followed the instructions to a t and the engine sounds great. The bike does cut out on warm up sometimes so the carb farts seems like the issue. Thanks all
Shibby46
Post by Shibby46 »
Just wanna check if anyone else has thoughts on my clicking problem above?
Thanks all
Difficult to say what the click is - have you a recording of it?
If the MCCT is too tight it'll squeal - and if too loose it'll rattle even after warmed up - so likely nothing untoward. Important thing it that the lock nut is done up, and you've put something on the threads to help stop them unwinding / stop oil dribbles - Just put a mark on the bolts and keep an eye on them while you ride for the first few miles.
Shibby46
Post by Shibby46 »
Wicky wrote: Sat Dec 05, 2020 10:21 pm Difficult to say what the click is - have you a recording of it?
Thank you, it doesn’t sound like either of those noices which is great, carb farts it must be 😊
The easy way to diagnose carb coughs is that you can feel it through the tank. If it's a cct problem you can't.
