Brake pads
Brake pads
Evening all, had a look at the front brake pads today as the braking doesn't seem that good, i measured the pad thickness and there is about 4-5mm left on them, is that getting a bit low?
Re: Brake pads
Nah there's loads left in them yet. If you take them out there should be a wear limit groove on them. It may be that the pads have glazed over. This can be sorted using a bit on emary cloth over the surface to rough them up or just get new ones.
Re: Brake pads
Are they green ?
4-5 is like new lol
Might be time to give the caliper a service
4-5 is like new lol
Re: Brake pads
They look a bit rough, ordered new ones EBC hh sintered pads off ebay quite cheap.
Re: Brake pads
shite I have them on rear be better going old school and putting my foot on back tyre
Brembos on front and are stunning
Re: Brake pads
Brembos or bendex or Lucas
But the pads are only one bit of the braking system .
Re: Brake pads
Can always send them back,
Re: Brake pads
Brembo's are fantastic but they have hardly any meat on them but they don't seem to wear down As Lloyd said though they are only one part. One of the best things you could do is pull the pistons out, check the seals, give the callipers a good clean (mine where like thick caramel behind the pistons) smear a bit of red rubber grease around the pistons and put them back in. Stick some nice pads in, fit braided hoses, fill the whole system with fresh fluid and bleed.
Re: Brake pads
You make it sound so easy but we all know there'll be atleast 4 hours of swearing when the flowers won't bleed properlycybercarl wrote:Brembo's are fantastic but they have hardly any meat on them but they don't seem to wear down As Lloyd said though they are only one part. One of the best things you could do is pull the pistons out, check the seals, give the callipers a good clean (mine where like thick caramel behind the pistons) smear a bit of red rubber grease around the pistons and put them back in. Stick some nice pads in, fit braided hoses, fill the whole system with fresh fluid and bleed.
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
'94 KTM LC4 400e
Re: Brake pads
Actually it's not the bleeding that's going to make one swear but getting the pistons out if seized/stuck in place. If your lucky they will just pop out if you squeeze the lever but they will most likely be a bit stuck, hence the brakes are not so effective and needing a service which is common to the standard Storm brakes.
Bleeding can be a pain if one is doing it by hand and doesn't have something to draw the fluid through. Clutch is the worst and it always helps if there are two people even if they just keep an eye on and top up reservoir levels.
Re: Brake pads
As always all help is gratefully received, just want all jobs done before any long trips for my own peace of mind, booked the ferry for the manx in august, will be at the tt also but not on my bike, looking forward to that.
Re: Brake pads
cheapest brembo pads seem to be carbon ceramic?
are they any good?
are they any good?
Re: Brake pads
The Red coloured ones for road use. And yeh as the Frosties tiger says theirrrr greaaaat. They are expensive and they don't have much meat on them but they perform well and don't wear down half as fast as EBC's or equivalent. Jonsey recommended them and I trust his judgement as our brake guru.cheapest brembo pads seem to be carbon ceramic?
are they any good?
Re: Brake pads
The Brembo pads are the dogs dangleys, fitted them to mine, i managed to do damage to my hand and my mate had to ride the storm home (he rides a bandit 600) when he got off he said he stopped so much quicker than his bandit and he had to pull away again to ride up my drive and nearly threw him self over the bars. i will not fit anything else on the storm now
Re: Brake pads
EBCHH pads are really good, never heard anyone say they're Shiite before, something wrong there I think.chric wrote: shite I have them on rear be better going old school and putting my foot on back tyre
Original Honda pads would be my choice though, Still got the originals in mine and the brakes are as good as they can be with plenty of feel, they do go off if the fluid is old though.
