kph to mph
kph to mph
have fitted a mph speedo to my bike was kph where can i get the part to make it calibrate so milage is correct and reads properly. also where can i get the milage corrected in cheshire area. thanks
ride it till the tires fall off then keep going !!!!!!!
Re: kph to mph
I think it's just plug 'n'play, there's no different part for the trigger end.
So as long as you haven't changed the gearing, it'll just read miles accurately.
However if you have changed one or both sprockets, you need a speedo-healer.
- cliveyandrews
- Contact:
Re: kph to mph
All works fine - no changes needed. I did mine years ago!
Sent from my iPhone using Tapatalk and my fat thumbs...
Audi, Vide, Tace
Audi, Vide, Tace
Re: kph to mph
where do i get the speedo healer and where does it go ?
Re: kph to mph
These people make themhttp://www.healtech-electronics.com/
http://www.ebay.co.uk/itm/Healtech-Spee ... 336ed90ce9
or there is this type http://www.ebay.co.uk/itm/VTR1000-Honda ... 4602dd31c1which I believe benny has tried.
- agentpineapple
Re: kph to mph
i should get one myself, but i can't be arsed, when my speedo reads 30mph i'm really only doing 24mph, so i know i'm ok with speed cameras..........cybercarl wrote:These people make themhttp://www.healtech-electronics.com/
although my mileage will be going up faster.....
Re: kph to mph
If my bike is say, an import and originally had a kph speedo that was replaced with one that had mph and kph on it. I wouldn't need a speedo healer right? I'm pretty certain I wouldn't but the obvious things are always the things I get wrong seems appropriate to ask on this thread
Re: kph to mph
Enter the vortex http://www.vtr1000.org/phpBB3/viewtopic ... 13#p255875
You should only need a speedo heeler if gearing has been changed.
- benny hedges
Re: kph to mph
leelee wrote:have fitted a mph speedo to my bike was kph where can i get the part to make it calibrate so milage is correct and reads properly. also where can i get the milage corrected in cheshire area. thanks
speedo DRD from http://www.12oclocklabs.com
ive got one on the sp and its spot on.
