Engine Damage noise.
Through all the bikes I have have had, only one has suffered with a damaged engine, I have had a mate blow his bike up before but I can honestly say I have never had a moment of " oh crap that doesnt sound good " Apart from a very feint tap noise when the CCTs were first done on warm up.
In work I have heard defective engines during test, and they stick out like a sore thumb.
So what does a bike sound like when it is about to suffer or is suffering an engine failure, are they one of the sounds where you go " crap " when riding and/or ticking over or are they somethig you need to know what your listening for.
Re: Engine Damage noise.
i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
top it back up and it goes away.
seb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
yeh, same here had a couple 2 strokes fook up but never had anything (honda) blow. sappose like anything, as long as its got cleanish oil in and the main things are tip top (CCT's, coolent) then its good to go
They wouldnt be two strokes if they didnt suffer heat seize every now and thenseb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
Got to love a two stroke.
I have never had a CCT go on a before, but apparently the CBR600 is one of the bikes where they seem to " go " the most frequent, fourtinatley I have heard you get a very loud ticking noise and inline 4 wont eat the engine like the storm.hugeduck wrote:seb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
StormingHonda wrote:They wouldnt be two strokes if they didnt suffer heat seize every now and thenseb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
In all fairness it wasn't my fault lol, i was used to the RM250 for what ever reason borrowed a mates RM125 and seized it in a few laps
Few other bits of crap too over time
Mates early R1 has let the CCT go but as said it still runs just very noisy
My mate had an Aprillia RS125, I was going to buy it for £100 it was a right off ( everything is a right off when hes finnished with it ) but someone else bought it and it seized within a week, the bike had been sitting and the 2 stroke in it was old.seb421 wrote:StormingHonda wrote:They wouldnt be two strokes if they didnt suffer heat seize every now and thenseb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
Humm, Seb honestly why let the oil get low to that point, that is asking for trouble especially if you like to ride on the rear tyreseb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
I've never had to top up the oil on a bike, even on my Harley, on my Zafira its a different story, juggler drinks oil.
darkember wrote:Humm, Seb honestly why let the oil get low to that point, that is asking for trouble especially if you like to ride on the rear tyreseb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
The previous original engine was a lot better than this one with regards to oil consumption, this engine goes from top of the line to the bottom level line in 200 miles
I ran it rich for a while which probably didn't help matters
Have to top it up every week after commuting on it, think it could do with new rings? but ill just keep throwing oil at it for now till i get the Engine work done on my orginal engine by Roger
200 miles to use that much oil, that just aint right at all, I never had to top up my Storm once when I had it in all of the 4ooo miles, I did one oil change but the oil level stayed the same.seb421 wrote:darkember wrote:Humm, Seb honestly why let the oil get low to that point, that is asking for trouble especially if you like to ride on the rear tyreseb421 wrote:i've had engines seize on two strokes but never a catastrophic failure with a four, when my engine oil runs down i get a louder rattle from the CCT chain (APE's fitted)
If its burning oil surely you would see this.
- benny hedges
got an r1 ape tensioner if your mate wants it
I put run it rich but I was supposed to put lean, no its not rite, on full throttle it smokes a bit, as said original engine was fine for consumption but can't be arsed sorting this one at the momentStormingHonda wrote:200 miles to use that much oil, that just aint right at all, I never had to top up my Storm once when I had it in all of the 4ooo miles, I did one oil change but the oil level stayed the same.seb421 wrote:darkember wrote:
Sent from my mobile telephone
good old 2strokes many a weekends pulling the pistons and getting re-bores .
put a hole in a piston once when running glow fuel 34% nitro , it was great till it went pop
Why does that not surprise me Lloydie?
