Engine Removal
freelander306
Engine Removal
Post by freelander306 »
Replacing engine in my storm the top mounting bolts are rusted in any advice on how to remove them ??????
Any help greatfully appreciated
bazza696
Re: Engine Removal
Post by bazza696 »
Tony.Mon is your man, he has taken out more engines than the time it takes blue storm gets to 100mph in seconds.
scott02464
Re: Engine Removal
Post by scott02464 »
bazza696 wrote:Tony.Mon is your man, he has taken out more engines than the time it takes blue storm gets to 100mph in seconds.
Now that is fast :lol:
darkember
Re: Engine Removal
Post by darkember »
Fek off bazza your just jealous cause u have a common as muck red one :twisted: :twisted: :twisted:
Re: Engine Removal
I think you might be heading to a hacksaw solution, but Tony will be along with his list of solutions he has tried.
heat & penetrating oil will be the starting point, but when these things seize up sometimes there is no moving them
darkember
Re: Engine Removal
Post by darkember »
AMCQ46 wrote:I think you might be heading to a hacksaw solution, but Tony will be along with his list of solutions he has tried.
You will also need the special castle tool which you can buy but it can also be fashioned out of a standard socket using an angle grinder. Cannot remember the size but someone here will know & add to this post
Re: Engine Removal
I made one of them out of a socket, but in the end I bought a double ended tool which has both on a 1/2" square drive..........much easier :D Scottyhitachi used it for his engine removal so we know it works, you can borrow it to if you dont already have one
Re: Engine Removal
I've been in touch via a PM.
