Hi all
Hi all
Hi, names Dave and im from sunny Essex. Just recently bought a Firestorm and loving every minute of it! Manual CCTs all fitted but it seems to have a very grabby clutch, i hear new clutch plates will fix it but which are the best? ebc?
So anyone else down here in essex?
Thanks
Dave
Thanks
Dave
Re: Hi all
Welcome to the forum mate. Not Essex but next door in Hertford! Work in Harlow. Where in TOWIE county are you?
Re: Hi all
Greetings
Try bleeding it first. Whereabouts are you? as might you want to compare another storm.
Re: Hi all
Thanks for the welcome! Live in Gt. Dunmow and work in Bishops Stortford so not too far away!
Ok thanks ill try bleeding it before i part with any £££, it seems ok when round town etc its just on hard takeoffs it feels "grabby", makes a noise sometimes too!
Re: Hi all
Welcome aboard buddy
Re: Hi all
hello mate. welcome to the club . your in the nice bit of essex there
Re: Hi all
hello and welcome .
most of the vtr's have a grabby clutch you will learn to ride with it
Re: Hi all
Welcome mate, my clutch is just the same. You just kinda get used to it.
Re: Hi all
Welcome aboard Dave
Besides changing the fluid, it could help if you remove the sprocket cover and clean out all the gunk from the chain lube and make sure the push rod moves freely, if that's not been down for a while. Just remove the clutch lever before taking the sprocket with clutch slave cylinder off. Otherwise with the clutch lever still fitted it will cause the slave cylinder piston to be pushed out making it difficult to refit the sprocket cover.
You may do that and find it makes no difference, but at least it won't cost anything more than your time to do.
- agentpineapple
Re: Hi all
welcome to the forum buddy, i broke down near dunmow yesterday
and i had a massive crash near there two years ago
its a nice part of the country with decent biking roads
Re: Hi all
Thanks for the warm welcome! Haha essex aint that bad! Some nice roads around here anyway, cant say much for the rest of it!
Thanks sirch345, ill have a look when i bleed it.
- chris vtr virgin
