Rear shock spacer + Lean angle
Hi all i would like to fit a 6mm rear shock spacer to my bike but what is the lean angle of bike with standard side stand anyone got any pictures of their bike from the rear with the 6mm spacer fitted with standard s/stand so i can look at cheers
Re: Rear shock spacer + Lean angle
5mm spacer and standard side stand
- thumperslaw
Am welding a block of steel under my side stand now
It leans way to much
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
Here's mine with a 6mm spacer and forks dropped 10mm.
If you use race scrubs it will lean over more
You are a bad influence. Got to get some new tyres soon, I'm either going BT023's or Pilot road 3's. My front is borderline legal if not illegal and the rear I want to change so I have a matching pair. I just wish tyres where not so expensive. I may just have to go for cheapy maxi's
Try Essential Rubber Carl.cybercarl wrote:You are a bad influence. Got to get some new tyres soon, I'm either going BT023's or Pilot road 3's. My front is borderline legal if not illegal and the rear I want to change so I have a matching pair. I just wish tyres where not so expensive. I may just have to go for cheapy maxi's
http://www.essentialrubbertyres.co.uk
E3 3JX
Got mine done there, ex-Storm owner, I told him I would put the word out on the forum & he knocked a bit off.
http://www.vtr1000.org/phpBB3/viewtopic ... 16&t=20599
