U S D forks
buzz
U S D forks
Post by buzz »
:D
hello FELLOW FIRESTORM FREAKS has anybody ever fitted any U S D forks on a firestorm if yes what forks were they and how dificult was it to do any help and advise would be greatly appreciated.
thanks
FIRESTORM FIRESTORM I LOVE MI FIRESTORM
see ya BUZZ :D
Stormtrooper
Post by Stormtrooper »
apparently blade front ends fit right onto storms withouut any difficulty
but daz is the man to speak to about that.
you will get him on the mcn site under the name stormsmasher.
Lucazade
Post by Lucazade »
The Fireblade forn conversion is based on the pre-'98 forks, which are not USD.
-- Luca.
Second-hand bike parts:
http://www.aboutbikes.co.uk
firestorm_al
Post by firestorm_al »
I'm sure I saw something about the 2001 forks and yokes fitting but I can't find it now.
Bloody expensive thing to be doing if you ask me. Either get the standard forks re-valved and re-sprung or go buy an SP1/2 IMHO.
Al.
delmeekc
Post by delmeekc »
Yep,
I'll go with that Luca, 97 Blade forks and yokes will go straight in, same calipers and everything. Go up to 98 Blade forks and the forks are about 30mm shorter (about 30 but as I'm not at home to check I'll just saw 30mm) and then the calipers have different mounts etc etc. I used 98 ones, much more fiddling about.
I think if you used USD's you would have big problems with radiator clearances on full lock and tank/bar clearance. Had an MV Augusta (can't spell) front end once but there was no way it was gonna fit.
Del.
Lucazade
Post by Lucazade »
Fireblade '98-'00 forks use different yokes (less offset and legs are wider apart - fnarr! fnarr!) which means you have to add new discs to list of parts to change (Blackbird discs can be used instead of the '98 Fireblade's, if necessary).
If you change the discs, it's not necessary to change calipers or use different brakets.
-- Luca.
delmeekc
Post by delmeekc »
Luca,
mine has 98 blade forks (Tech 2000 revalved and sprung), with AP GP discs, 98 blade PFM calipers and the yokes are 225 centres (98 blade plus 10mm) for the endurance quick release mechanism and 27.5mm offset. Had me yokes made to 50mm and sleeved down to 45mm so that even bigger forks could be used if needed.
Del.
Lucazade
Post by Lucazade »
delmeekc wrote: bla bla bla
Sorry, your point being...?
-- Luca.
delmeekc
Post by delmeekc »
fik me your touchy, got the painters in have with.
:lol:
Del
firestorm_al
c'mon kids, this aint Visor Down :lol: :lol:
Lucazade
Post by Lucazade »
Naaah, just taking the mick!
:lol: :lol: :lol:
-- Luca.
essexbloke
Post by essexbloke »
i was talking to a guy at the BMF in September, he was telling me about his track-day VTR, which he fitted a ZX9R front end to, he reckoned
it needed "a bit of machining", but otherwise was easy to fit, and really beefed up those saggy forks we all know & love...
anyones else heard of this one????
