I'm keeping an eye out for a decent pair of front discs for the storm and have been trying to check which other models will fit, some info collected is shown below incase it's of use to others:
Outside Diameter 296
Inside Diameter 58
Bolt Hole Circumference 74
Bolt Hole Quantity 6
Bolt Hole Size 6.5
Thickness 4.0
Minimum Thickness 3.5
Offset 17.0
Type of Bolt Holes STRAIGHT
http://metalgear.com.au/mgear-brake-dis ... -6304.html
EBC info
VTR1000F FIRESTORM 1997-2006
Will also fit the following models
CBR400 RRJ/RRK (NC23) TRI-ARM 1981-1989
CBR400 RRL/RRN/RRR (NC30) GULL-ARM 1990-1994
RVF400 RR/RR2/RT/RT2 (NC35) 1994-1996
VFR400 R3K/R3N/R3L/R3M NC30 1989-1992
CBR600F FS/FT/FV/FW 1995-1998
VFR750 FR/FS/FT/FV 1994-1997
CBR900RR FIREBLADE RRR/RRS/RRT/RRV 1994 - 1997
EBC PART NUMBER MD1003X
I think some Aprillias had the same size discs but haven't found that info yet.
Front disc dimensions
I put the disc and front wheel stuff in the work shop knowledge base as a sticky when I get home I will add yours to it
