Ebay Finds (unusal/cheap/rare/or just good value)
Moderator: VTRDark
- agentpineapple
Re: Ebay Finds (unusal/cheap/rare/or just good value)
looking at the marks, it will need respraying any way.
- agentpineapple
- agentpineapple
heres one for the street fighters
http://www.ebay.co.uk/itm/Streetfighter ... 2319ca4c75
i know this is for a fireblade, but i'm sure it could be converted for a firestorm........
- agentpineapple
blue vtr with loads of extras on ebay
yoshi cans
moriwaki style bellypan
tinted screen
gear position indicator
aftermarket rear shock
crash protection.....r&g bar ends, r&g carbon fibre exhaust protectors, r&g crash bungs
rear hugger
what might be a carbon fibre front mudguard
tank grips
and what looks like good rubber aswell
but he doesn't state the mileage or weither its running standard cct's or r/r....
the condition looks good for a 2000 bike even if the colour is not one of the most inspiring options. depending on mileage its got to worth 1200 to 1400.
http://www.ebay.co.uk/itm/2000-HONDA-VT ... 3371cfd638
tinted screen
rear hugger
tank grips
http://www.ebay.co.uk/itm/honda-vtr1000 ... 500wt_1380
Rear tail section in original shiny condition - Y-124
- agentpineapple
it will do the job mate, i just liked the extra power you get from the bigger battery which only costs an extra £10, having said that if you only ride in normal weather(not the freezing cold) the smaller battery should be ok....
- agentpineapple
you would only be able to use a 16" front wheel with them forks as they have a wider calliper spacingbigspanishmarty wrote:http://www.ebay.co.uk/itm/Honda-Cbr-900 ... 3a7071bcfe
- agentpineapple
i thought you could put the 17inc front wheel on any of the older blade forks mate....i don't know for sure tho
only.94-97bigspanishmarty wrote:i thought you could put the 17inc front wheel on any of the older blade forks mate....i don't know for sure tho
98 had a wider stance by 10mm
So if you used 98 forks with 97 yokes the calipers would need spacing out by 2.5mm each side
The 92-93 forks the brake calipers need spacing in 2.5mm each side and new wheel spacer need making .
But the 94-97 fit without modification
- agentpineapple
looks like a renntec grab handle on ebay
they normally sell between £20 to £25 theres no fitting kit with it tho, so you'd have to bodge something together for it.
http://www.ebay.co.uk/itm/HONDA-VTR-FIR ... 27c3740f7c
- agentpineapple
almost as much as the zorsts mate..........
