running rough
- thumperslaw
running rough
Got my storm back on the road the other day after new motor been stuck in it and every thing seems fine....until you ride it.
If I hold it about 4-5rpm it stutters thru the rev range in all gears. I have stripped the carbs more then once today and checked coil packs plus plugs.
Using 190 jets with two turns on the pilot screws. Needle hight is on number
4. Pulling the coke on don't help still does it.. like trying to ride a bull
Any idea?
Any idea?
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
Re: running rough
Check all hoses are fitted correctly, unkinked and with no leaks - esp the vacuum hose that fits to the fuel tap, round the back not the more obvious but wrong 'spigot' on the bottom.
Try cracking open a pepsi, failing that a redbull and hang on tight4. Pulling the coke on don't help still does it.. like trying to ride a bull
- thumperslaw
Re: running rough
Wicky wrote:Check all hoses are fitted correctly, unkinked and with no leaks - esp the vacuum hose that fits to the fuel tap, round the back not the more obvious but wrong 'spigot' on the bottom.
If that where the case then the bike would run rough from tick over?
K100 "flying brick"
K100 "flying brick"
Re: running rough
Shouldn't the main jets be different for the front and back carbs or am I imagining that? Someone who knows will be along soon.....thumperslaw wrote:Got my storm back on the road the other day after new motor been stuck in it and every thing seems fine....until you ride it.
Any idea?
Worth checking the vacuum hose placement though. It has been done before.
- thumperslaw
Re: running rough
Think I my of got to the bottom of it now!Stratman wrote:Shouldn't the main jets be different for the front and back carbs or am I imagining that? Someone who knows will be along soon.....thumperslaw wrote:Got my storm back on the road the other day after new motor been stuck in it and every thing seems fine....until you ride it.
Any idea?
I washed the k&n filter and my of over oiled it
Always netted both carbs the same and worked well for me
K100 "flying brick"
K100 "flying brick"
Re: running rough
As standard the jet sizes are slightly different front and rear, but with a jet kit they are often recommended to be the same.
Get it on a dyno and if the operator's skilled enough and experienced with Storms he'll be able to try both options and show you the differences on the charts.
- thumperslaw
Re: running rough
That's the next step is get it fine tuned on dyno. First I want to get it running right.
K100 "flying brick"
K100 "flying brick"
- thumperslaw
Re: running rough
Going to change the the front coil pack see if that helps
K100 "flying brick"
K100 "flying brick"
- benny hedges
Re: running rough
sounds very much like the problems ziggy had with his & turned out to be a bad tankfull of fuel.
- thumperslaw
Re: running rough
Done the whole fuel thing and still running right.benny hedges wrote:sounds very much like the problems ziggy had with his & turned out
K100 "flying brick"
K100 "flying brick"
- thumperslaw
Re: running rough
So far i have re-jetted again and still no joy
Done
Full compression test
Leak down test
Checked fuel lines
changed exhaust
changed carbs
cleaned carbs
checked coil packs
checked spark plugs
Done cam timing
And...........Still not got to the bottom of it all!
Aghhhhh
Done
Leak down test
Checked fuel lines
changed exhaust
changed carbs
cleaned carbs
checked coil packs
checked spark plugs
Done cam timing
Aghhhhh
K100 "flying brick"
K100 "flying brick"
Re: running rough
Try a standard OEM air filter to try and get everything back to 'normal'.I washed the k&n filter
- thumperslaw
Re: running rough
I would but that means changing full system and going back to standard jetting
Coasting me loads of money changing things left right and centre
Just got some emission tubes coming
K100 "flying brick"
K100 "flying brick"
Re: running rough
Not if it's just for test purposes.thumperslaw wrote:I would but that means changing full system and going back to standard jetting
Just try running the bike with no filter in the airbox for a mile or two.
It won't do any damage over that short time.
If it runs ok, it's your over-enthusiastic oiling of the filter- you won't be the first.
- thumperslaw
Re: running rough
Done that with the air box alreadytony.mon wrote:Not if it's just for test purposes.thumperslaw wrote:I would but that means changing full system and going back to standard jetting
Clean air filter and let it dry then ran it. Still same
Oiled it no joy
K100 "flying brick"
K100 "flying brick"
