Lead Acid Batteries
Jetblack
Lead Acid Batteries
Post by Jetblack »
Probably a silly question! But can you usenormal lead acid batteries on a 98 storm or do they have to be the gel type
atb JB
vtrman44
Re: Lead Acid Batteries
Post by vtrman44 »
hi jb
you need gel one ,acid one no good,because battery is on slant ,acid would not cover plates,i was going to get one till battery guy told me hope this helps.
john
tattoo
Post by tattoo »
hi jetblack
use a motobatt quadflex battery....code MBTX12U...
20% higher cranking power...ideal for vtwins
maintainance free,never needs water
no acid to spill
no initial charging needed
install and go
they are alittle more expensive than the OEM battery but well worth it
