What is the best way to get rusted exhaust studs out?
Fasten 2 nuts over the stud and anti clockwise on the first nut?
If you arent going to reuse the stud as it is rusty, would you just use a vice or mole grips to turn them, knowing that this will damage the thread so no going back if they wont come out?
Exhaust studs
Re: Exhaust studs
The studs are 8mm on the engine side and 6mm on the flange, I warmed mine up gently and thenm worked them back and forth about a 1/4 turn at a time, took my time and they came out. I replaced the original different sized studs with a Stainless Steel 40mm long set screw with the head cut off to make a stud , wound them in with double nuts then put exhaust on and used domed 8mm nuts to hold the flange in place ..
Re: Exhaust studs
get your self a set of these
spot on for removing studs
the some stupid 7mm size not 6arnie wrote:The studs are 8mm on the engine side and 6mm on the flange
