AIR FILTER !!
AIR FILTER !!
Call me Mr. Stoopid, but how do you replace the air filter on a Storm..??
Take the front mounting bolts out of the tank, lift it up, undo all the screws in the top of the aircleaner cover, then lift the cover off. Pull the aircleaner element out, cut all the paper away, then glue in the Unifilter foam you've carefully cut to fit. Spray it with foam filter oil, then replace everything ('cept the paper).
OTOH, you could just throw the paper elephant away, and replace hte whole thing with a new one, like most people do.
OTOOH, you could buy one of them expensive K&N filters.
- Ian in EnZed
(Red 97 FireStorm with Dynojet kit, APE camchain tensioners, bafflectomy+ploogs, UniFilter, GenMar risers, Avon Azaros, 90/130W headlight, digital clock/voltmeter), Braided s/steel lines.
