My shock spacer came today - disamapointed....
- cliveyandrews
- Contact:
I guess I expected a massive great piece of milling - but when you think about the size and placing of it - it's not gonna be that big.....
Lets hope it shows an improvement...
Audi, Vide, Tace
Audi, Vide, Tace
- cliveyandrews
- Contact:
Re: My shock spacer came today - disamapointed....
PMPL.....
I'm not dyslexic - just "special..."
Audi, Vide, Tace
Audi, Vide, Tace
- Pete.L
Don't be disamapointed, it'll work
What size spacer have you gone for in the end?
- cliveyandrews
- Contact:
3mm.........
Curious to see what that'll give me...
Audi, Vide, Tace
Audi, Vide, Tace
.. about 3mm I reckon
I'll get my coat.
I'll get my coat.
“Only by constantly developing your insight and knowledge can you fulfil your responsibility to ride safely and effectivelyâ€
- cliveyandrews
- Contact:
Hehe - apparently 11mm...
"TRANSFORM CORNERING OF YOUR VTR1000 BY FITTING THIS SPACER TO REAR SHOCK, NO MORE RUNNING WIDE IN CORNERS, BIKE STAYS ON LINE WHEN THIS FITTED.
3mm thick
EASY 10 MINS TO FIT, JUST LOOSEN TOP SHOCK BOLT SLIP SPACER IN AND RETIGHTEN.
CHANGES STEERING GEOMETRY BY RAISING BACK END BY APPROX 11mm."
(http://cgi.ebay.co.uk/VTR1000-VTR-1000- ... 6215565745)
3mm thick
Audi, Vide, Tace
Audi, Vide, Tace
heh. Let me know how you get on with it. I might nab one if works out for you.
Are you coming to OP Storm II btw?
- benny hedges
if it was one of the little farty 3mm thick spacers they do make a difference believe it or not.
know what you mean tho - i got one & thought wtf! looks too thin to make a difference
took mine out after a while - still got it somewhere on the garage floor buried under piles of other unwanted tat.
a square unistrut washer with the hole slotted out is better imo
It looks more than 3mm thick in the e-bay pic
Everything good is bad
Everything bad is good
- cliveyandrews
- Contact:
Erm, possibly....geodude wrote: Are you coming to OP Storm II btw?
When/where (I'm a bit behind on the site at the moment)....?
Audi, Vide, Tace
Audi, Vide, Tace
- cliveyandrews
- Contact:
Yes, found it, mapped it - and commented...
Audi, Vide, Tace
Audi, Vide, Tace
- Pete.L
It's an age old topic. Roger Ditchfield recomended 3 -6 mm. After 6 mm he said you can suffer with instability problems so not to go any further.
I cut one from a 4 mm bit of plate I had lying around and I was very pleased with the result.
Just loosen the top nut on your shocker, lean the bike over onto the side stand, slip in the spacer, tighten the nut back up and away you go As quick as that
I went straight to 6mm and waited to fall off.
Nothing, it's fine.
Handles better, tips in nicely but can get slightly squirrely over cats-eyes accelerating hard with squared-off tyres.
Nothing to throw you off or make you shut the throttle, though.
Nothing, it's fine.
