front forks fireblade?
vtrandy
Post by vtrandy »
can anyone give me info on fireblade front forks to fit my firestorm ie year model of blade do i need the wheel yokes brakes?or any other parts, is it a straight swap? is it the 16 inch wheel model also?oh and has anyone got the parts?
ive also been told sp1 or2 front end fits :?:
andy
There's plenty of info on this, here on this site, all you need to do is go back and find it in earlier posts, hope that helps,
cheers Chris.
Just had a look, try " blade forks " all the info is there from Del.
cheers Chris.
vtrandy
Post by vtrandy »
thanx guys
andy
iggy1966
Post by iggy1966 »
http://www.vtwo.demon.co.uk/firestorm/firestorm.htm
This seems to have all the info you require.
chris56
Post by chris56 »
Have been advised that if you don`t want too spend all that money just fit New Ohlins fork springs & heavier Oil & Ohins rear shock & U have a REAL WINNER :)
chris56
Post by chris56 »
chris56 wrote:Have been advised that if you don`t want too spend all that money just fit New Ohlins fork springs & heavier Oil & Ohins rear shock & U have a REAL WINNER :)
Fast is Good but FASTER is Better!!!!!
