Standard baffles-just drilled or out altogether?
Hi all, have put standard pipes back on my bike, and have read all the posts about drilling 4 or 8 holes etc, and then the ones about 'bafflectomy'
has anyone got any opinions on this?
Would especially like input from those who have removed the end baffle as opposed to the drilling, but all opinions welcomed.
Cheers, Chris.
Cheers, Chris.
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
- bikerpiker
Ive done it , first i drilled out eight 9mm holes...ran for a while then wanted more ,so drilled them out to about 12mm....,cans sounded really good ,much better than standard ,really nice on the over-run as well
Decided i wanted them even louder ,so cut from hole to hole with a small sharp chissel ,a couple of clouts and a wiggle ,and out come the baffles ,then cleaned up with a dremmel ,but could still tidy it up a bit A hole saw might do it as well
Now a lot louder ,but somehow not as nice sound on the over-run
http://www.vtr1000.org/phpBB2/viewtopic ... es&start=0
Stevie
- bikerpiker
I found breaking the internal tack-welds which hold the end baffles easy after i had chisseled from hole to hole, a couple of clouts and a few wiggles and out they camecustard wrote:Bafflectomys rock my world.
Sounds like the end of the world when I'm driving through the narrow village street near my house.
If I'm ever feeling down, I go for a blast and the noise makes it all good again! Did take me hours to break the internal welds of the baffles though!
The hardest most time consuming bit for me was tidying up the cut with a Dremmel , the wee grinding stones i used were shite , too soft
Stevie
- firestorm996
- Contact:
Just drilling them sounds shite, I tried it for about 5 minutes then rode straight back home and finished the job.
Drill the holes, join them up as much as you can then completely seperate the baffle tube from the outer part by chiseling the holes into a complete circle. Then tw@ the baffle until it comes free inside the pipe. Then tidy up the mess caused by drilling earlier. Then fire up your bike, crack a beer open and enjoy.
Firestorm996
'98 VTR in black - road whore - track bitch
Re: Standard baffles-just drilled or out altogether?
Hi all, so far, i've drilled 8x10mm holes and it sounds quite nice.
What i want to know is how much louder is the bike with the baffle completely removed? Twice as loud? three times as loud?
All input welcomed.
Cheers, chris.
All input welcomed.
Cheers, chris.
- bikerpiker
Really hard to say,mate..drillin the holes was a huge improvement over standard,but i thought there was always a kinda pft,pft,pft,pft noise
With the end baffle removed its poss twice as loud ,but it's definately not too loud
Stevie
Have since removed end baffles completely and love the sound!! Quite a nice bass tone without the harshness of the microns.
I hadn't realised they sounded "a nice bass tone" with that modJonesey wrote:Have since removed end baffles completely and love the sound!! Quite a nice bass tone without the harshness of the microns.
- bikerpiker
For anyone who wants to see what the cans look like with this mod done, here's a wee piccy or two
In the 2nd pic you can see the hole where the removed baffle has been You can also see what looks like another two baffles,....remember ,all this is only visible cos of the camera flash ,or if you were looking in at the correct angle in bright sunlight
Back tyre soaking, infact bike was soaking with condensation in my garage
Stevie
I thought I would try something like this instead,
first drill a pilot hole of 5mm on the left then the right of the baffle then under the baffle, as in 1 pilot hole at 9 o'clock, 6 o'clock and 3 o'clock with the main baffle still in the middle of these holes, do the same to the other exhaust. Now drill all these holes out with a 13mm drill bit, please use HSS bits, good sharp ones!!
Heypresto, ,nice sounding exhaust, not too loud but deffinately louder and still sounds gorgeous on the overrun, not tinny but kin fab.
I did it to mine and it sounds great....
- bikerpiker
Give it a week or two and the drill will be out again
I agree a huge improvement over standard, but think how good it would be with 8 holes each can
Actually i was so impressed with the baffle modification on the Firestorm , that i searched and found info regarding doing it to my Bandit.......job done ,sounds real good ..............Not as good as a v-twin though
Stevie
Nah,... I think 3 holes at 13mm plus the baffle is enough, anymore and it's too loud and draws the wrong kind of attention, this way it's just nice, not muffled and not deafing but headturning .bikerpiker wrote:Give it a week or two and the drill will be out again
So to do this mod you just drill the 3 holes in the end plate of the exhaust and not into the baffle ?BBUK01 wrote:Nah,... I think 3 holes at 13mm plus the baffle is enough, anymore and it's too loud and draws the wrong kind of attention, this way it's just nice, not muffled and not deafing but headturning .bikerpiker wrote:Give it a week or two and the drill will be out again
- stormingjoe
- Contact:
straight froooo vipers are the way to go, espesh with a friendly mot man, bbboooowwaaaa pop pop pop bbbboooowwaaaa
