got no go
got no go
Right I've just finished getting my storm back together after having the frame powdercoated, the tank plumbing was previously all wrong so that has been rectified, took it for a spin and its running fine but just doesnt seem as quick as it did , like its asthmatic for want of a better word, is there anything i could of missed?
Are you positive the pipe for the vacuum is connected to the correct outlet on the tap This is the earlier version 16ltr tank model, not the later version 19ltr tank model I'm referring too.
If you look at the tap, the outlet that faces the ground on the bottom of the tap is just a drain out-let, (Fuel will only leak from there if the diaphragm has split.) the vacuum pipe should not be attached there
Or if you unplugged the TPS (throttle position sensor) plug have you forgotten to plug it back in
