I've been trying to find the original "dpr9evx 9" spark plugs or equivalent but found nothing at all except NGK sites saying they have ben replaced with f#cking expensive iridium.
Surely the equivalent DPR9EA-9 normal plug will work just fine?
I'm just shoving some new pluigs in as my storm has become a sod to start now it's cold, hoping new plugs will improve things a bit.
Ratty
Can I use any other plugs apart from iridium?
Hi Ratty,
Personally I would fit the iridum s/plugs as I find they are better than the original OE fitment. If you go for the original ones for what ever reason I expect you'll end up getting the iridum ones later. I realise if things are tight you have to do what you can.
Here's where I gotr my iridium s/plugs (best price I could find:-
CLICKY
Original fitment (going by the plug number you've written above) from the same guy:-
CLICKY
CLICKY
CLICKY
I've been getting my plugs from http://www.sparkplugs.co.uk , seem pretty cheap.
