rear shock spacer
rear shock spacer
Just a quick one for those in the know, where do i get it from, where does it go etc etc, just want to raise the butt a bit.
cheers all
Kirk
cheers all
Kirk
Smile..........it confuses people
http://picasaweb.google.com/Kirk6471/FinalRebuild2#
click above to see the final rebuild !
Here's how to make one...
http://www.vtwo.demon.co.uk/firestorm/firestorm.htm
I'm going to make myself a couple of 3 mm ones for when I put my new shock on next week.
There are usually made ones on ebay for about a fiver as well.
"military intelligence, two words combined that can't make sense"
- Stormin Ben
Shaun's spacers are NEARLY right
However, to fit them you need to remove quite a bit of the back end of the bike to get it over the bolt
I adapted the design a bit and could fit/ remove them at the roadside in minutes
And FWIW I ran 4mm on the road and 6mm on track
But its not a very good one!
Andy never used em mate i have ohlins shock and blade front end mine are slightly different to bens they have the slot cut out for easy change made from washers the same diameter of the shock mount but with the slot cut out for the thread.
mine have already been claimed today by pm but i can knock some up if anyone wants any
cheers Lee, your a star, got it today in the post, have not looked how to fit it yet but will have a bash tonight once kids are in bed. can't be that hard i guesss, could give me a clue though if you want
cheers mate
Kirk
cheers mate
Kirk
Hi all,
Been looking at this on Ebay today,
http://cgi.ebay.co.uk/HONDA-VTR1000-VTR ... .m14.l1318
Will it make much difference to the handling?
Often thought about it but never asked!!!!
Just replaced my shock today and put a 3mm spacer in. Feels a lot higher to sit on and more weight on my arms - but i'll get used to that. Seemed really stable and turned ok but I won't know until I sort my fork seals (again!!! )
I made two and the other one is free to a good home but I didn't cut the slot in so you would have to do that or drop the shock to fit it.
