Just fitted some small indicators by motrax,only prob i have now is the large gap around them.I have seen them little plastic,inserts that you stick in the fairing,and mount the indicator on top of,does any body know if they are available for the storm,or do any other models fit?? :CheersD
Cheers,will have to put up with the holes,shame really as they are nice pieces of kit and really bright,not like the rears,from killerkawasaki.Mot man laughed at them!! will think of summat,another bodge in the pipeline!
I did find some of those plastic things to cover the holes on the rear of the bike after fitting LED indicators to my Storm. I think the ones I had were for a Yamaha of some sort. If that's what you want (for the rear) let me know and I will try to find out exact info for you,
Thanks,have checked out the motrax indy spacers,at my local bike shop,on the back of the packet,they list Cbr600,SP1 etc,but not storm. Took them outside,and they looked well to small to cover the hole,seems the storm has a bigger hole than those particular models.No worries thanks all...
Had the same problem, but I'd already bought the covers without measuring up....
in the end I fitted the teardrop shaped flush ones which fit fine and cover the hole.
Pass a MOT, too.
Well here's my Indy Spacers from Motrax, they do the job for me ok
They are meant for the R1, 2002 onwards and the R6, 2003 onwards, as you can see on the chart
Sorry mate should have been a bit clearer,it was the fronts i was after.Anyhow managed to shape a bit of ally that does the job,its been vaq blasted and laquered,just stuck the original rubbers on,with loctite glue,strong stuff...Sorry about pics getting a bit dusky here.Cheers. [img][img]http://i258.photobucket.com/albums/hh26 ... bay067.jpg[/img][/img]
