Cog Question
firestorm_al
Cog Question
Post by firestorm_al »
I currently have standard size front and rear sprockets front and rear. The question is, is it ok to keep the same length chain if I go down one tooth on the front sprocket??
Al.
firestorm996
Post by firestorm996 »
Don't see why not, mine's been like that for the last 18k.
Firestorm996
'98 VTR in black - road whore - track bitch
firestorm_al
What are the standard sprocket sizes for the Storm again??
I did try a search on the Yahoo e-mail group but the search facility seems to be pretty cr8p lately.
Al.
firestorm996
16 tooth front
42 tooth rear
Firestorm996
firestorm_al
I thought it was a 41 tooth rear?
firestorm996
Well if a standard one is 41, that may account for why my speedo is 16% out instead of the usual 14% :biggrin
I currently have a renthal 42 rear and a 15 front, I was assured the rear was standard and there was too much gunk on me old one for me to be arsed counting em. :wink
Firestorm996
firestorm_al
So how is your storm on the track with that gearing?
firestorm996
Haven't had it on track since I changed the rear, but the 15t has been on pretty much from new. It pulls nicely and there aren't any gaps between gears, never had a problem with it as it is.
It's been to Cadwell, Darley (twice), Oulton Pk and the Nurburgring so far.
Firestorm996
firestorm_al
What I need to be able to do is the hairpin at knockhill without stalling it in 2nd or having to drop down to 1st!
firestorm996
That's precisely the problem on standard gearing m8, there's a huge gap between 1st and 2nd. The other gears aren't as bad but the easiest fix is to whack a 15t front or a 43t rear (less severe). The rest of the gearing (3/4/5/6) doesn't suffer as you're only talking a few hundred rpm difference. Plus if you think about it there's less load on the engine too if the gearing is shorter, which is a good thing.
Firestorm996
firestorm_al
15 tooth sprocker arrived this morning. Hopefully get it done at the weekend.
In the meantime, I fitted a Sigma computer to the bike to give me a realistic speed measurement after I've changed the sprocket.
A usefull wee formaula to have if you've fitted one and are trying to get the callibration correct is -
new_circumference = real_mph * old_circumference / displayed_mph
A good way of doing it is to zero both the origonal trip and the Sigma trip then go for a long ride. Take a note of the recorded trips on both then insert them in the above formula instead of the mph figures.
Al.
firestorm_al
After my run last night the callibration figure with a ne MEZ3 tyre is 1144.
Just need to get the front cog fitted and take a couple of pictures of my Sigma pickup mounting just for the record.
Al.
