Well managed to get some time in the garage again today and did all the final little jobs that I had short cut so I could get the last test ride.
Took the sprint steering damper off and sent it off to get the air taken out of it (Sprint don't deal with the old down the side of the frame types anymore, so I sent it to one of their ex employees who is looking after these)
Fitted the Nitron shock
Fixed an oil leak from the rear CCT gasket
Swapped the rear cam cover for the one of the original engine as I forgot to take my own advice and put gaffa tape on it to avoid the frame scratching it when it goes over the top.
Balanced the carbs
Did a compression test 150psi back and front
Put it all back together and nipped out for a quick 20 mile shake down.
I am liking the riding position, works so much better for normal riding and has no draw backs when you decide to Press on a bit (or a lot
). It is also generating less wind noise on my helmet as I must be above the turbulent air coming off the screen. It does need the steering damper back on or I need to learn to hold on less tight when the speedo is moving round the dial to the big numbers, but was all good so happy bunny
Well except when I met a van coming the other way when there was 2" of standing water and I got a face full of tidal wave
![Sad :(](./images/smilies/icon_sad.gif)
